Another Interior thread
Old Mar 28, 2021 | 06:08 PM
73racevette's Avatar
73racevette
Originally Posted by Mooser
I'm guessing it's the usual problem, it frequently gets caught up on the underside of the shifter console or it's bent down and jambs into the kick-up on the tunnel there, needs to have the leading edge pushed down under the console to get started or bent up so it doesn't get caught on the tunnel, then it's usually ok
now if your shift console isn't in yet...
M
thanks. After pulling my shift console out...again, the plastic piece had jammed under the wire holder that is riveted to the body. A drill to remove the rivet, works good again. Now to get the shift console back in. Fun times.
