AC Wiring to Relay
Old Aug 26, 2020 | 12:13 PM
71stingrayvette's Avatar
71stingrayvette
5th Gear
Default AC Wiring to Relay
1971 convertable with AC
My connector to the relay was fried and I am installing a new relay and connector.
I am trying to find out which wire goes on each terminal.
The upper left is #2
The upper right is #3
The middle Is #1
The bottom one is #5
Any help on which color wire goes on each terminal would be appreciated
Old Aug 26, 2020 | 02:02 PM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
I hope this helps! Courtesy of Willcox Corvette!
Old Aug 26, 2020 | 02:13 PM
71stingrayvette
5th Gear
From what I can see:
Orange wire goes to #1
Dk Blue to #2
Purple to #3
Blk to #5
Is that correct?
Old Aug 26, 2020 | 02:36 PM
Primoz's Avatar
Primoz
Should be correct
Old Aug 26, 2020 | 04:59 PM
71stingrayvette
5th Gear
I see the Orange Purple and Dark Blue wire. Any idea what the other (maybe tan() line goes to?
Old Aug 26, 2020 | 05:37 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Make sure you get that plug tight on the relay. They get loose heat up and you won’t know.
Old Aug 26, 2020 | 10:41 PM
71 Green 454's Avatar
71 Green 454
You should have 2 orange wires, 1 is 12 ga. that feeds 12v to the high speed relay from the horn relay via a 30 amp inline fuse. The other orange wire is an 18 ga. that goes to the anti-dieseling relay. They are both crimped together at the high speed relay connector.
Old Aug 27, 2020 | 08:50 AM
71stingrayvette
5th Gear
Thanks for the information
To AC Wiring to Relay
