Does anyone know
Old Aug 28, 2020 | 01:13 AM
Two C3's 4 me's Avatar
Two C3's 4 me
Default Does anyone know
where this is supposed to go besides NOT on the exhaust manifold. 72 LT 1 with factory air. I do not see any empty plugs where this could fit or be inserted. its location is by the ws door actuator I was wondering that perhaps it was supposed to go into the water temp sensor between 6 and 8 hhhhhhhmmmmmmmmm Thanks in advance
Old Aug 28, 2020 | 09:15 AM
kansas123's Avatar
kansas123
Does your car have A/C? This looks like part of the harness and should have what's called a thermo limiter fuse plugged into it.
Old Aug 28, 2020 | 09:42 AM
Two C3's 4 me
I don't think that is it as the thermo limiter switch/fuse has different colored wires and mine is visible in photo number three with a tie down attached to it just to the left of the melted plug and yes it does have AC, thanks
Old Aug 28, 2020 | 10:03 AM
BarryB72's Avatar
BarryB72
Are those wires this color?
Old Aug 28, 2020 | 10:30 AM
Two C3's 4 me
The wires going into the plug are 2 orange green and blue. There is no way it would reach to the front of the motor
Old Aug 28, 2020 | 10:33 AM
MelWff's Avatar
MelWff
Your car came with a transmission controlled spark advance. On the passenger side of the carburetor is there a vacuum device connected to the distributor vacuum advance?
https://www.opgi.com/air-fuel-delivery/carburetor-accessories/tcs-solenoid/tcs-solenoid-1972-checmc-big-block-ch28942.html?gclid=Cj0KCQjw1qL6BRCmARIsA DV9Jtb6OAMuVulYTeRwCyCEYMi0xTNlfA0ENQrqo dSDfGLnra_abmeG_DMaAlNVEALw_wcB
Old Aug 28, 2020 | 10:35 AM
BarryB72's Avatar
BarryB72
TCS solenoid harness
Old Aug 28, 2020 | 10:40 AM
71 Green 454's Avatar
71 Green 454
Attachment 48311871
Old Aug 28, 2020 | 10:41 AM
Two C3's 4 me
No there is not such a device there. I do not believe this plug would reach the location that your picture shows
Old Aug 28, 2020 | 10:43 AM
Two C3's 4 me
That might be it but I do not see that vacuum device on the intake manifold so it has been removed by PO
Old Aug 28, 2020 | 10:45 AM
Two C3's 4 me
Thanks guys that looks like the culprit...
To Does anyone know
