1982 Engine Ticking
Old Aug 28, 2020 | 05:18 PM
Axeonelite's Avatar
Axeonelite
4th Gear
Default 1982 Engine Ticking
This is a new noise for my engine. Nothing has been changed since I got the car. Please see my prior post if you have any questions about what it in the car. We did have to replace the transmission shifter cable but that's the only work I've done to the car besides fixing a power steering leak.
It sounds like it's coming from something under the drivers side valve cover but I am not sure where to start investigating. The only reason I say drivers side it because it does sound louder on the drivers side to me. Also it is "in time" with the engine, so if I rev it up the ticking speeds up to match. I haven't really let the car heat up to see if it goes away or gets quieter because I wanted to be better safe than sorry and not drive it when I wasn't sure.
Just trying to get some ideas. We are going to be taking the engine a bit apart to replace the Intake manifold gasket so we are going to look at everything else while we are in there. This is my first vette and maybe I've just never noticed the noise before? If all sounds normal to you guys just let me know but again, rather get a second opinion before risking a trip in it.
AUDIO WARNING. The way my phone recorded the audio it tried to focus on the noise itself and drown out the engine noise so it goes in and out. Don't turn up too loud LOL.
Old Aug 28, 2020 | 05:23 PM
MelWff's Avatar
MelWff
Use a piece of rubber hose to act as a stethoscope and located the source of the noise.
Open the breather and insert the hose.
You can also remove the valve cover and see if it is a specific valve making the noise.
Old Aug 28, 2020 | 09:46 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I see what the issue is....It has a carb on it instead of CFI. OK, jus kiddin'.
To 1982 Engine Ticking
