Installing lower radiator hose
Old Aug 30, 2020 | 07:26 PM
Mpls Funk's Avatar
Mpls Funk
Default Installing lower radiator hose
HI all - any tips for installing the lower radiator hose? Is there any lubricant you can use to help get the hose to slide on to the radiator neck easier? I have some silicone spray lubricant...can I spray that on the radiator neck, or will that do harm to the hose or cooling system? Any other suggestions/tips?
Old Aug 30, 2020 | 07:48 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
dont use a lubricant, it will slide off when you tighten it up. I use the indian head shellac on all my hoses and it will act as a lubricant and harden once it dries. You dont have to use the Indian head but a good sealant will help it slide on easier
Old Aug 31, 2020 | 12:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
Smear some dishsoap on the inside of the hose
Old Aug 31, 2020 | 02:40 AM
Bikespace's Avatar
Bikespace
Make sure the spring is in there first!
Old Aug 31, 2020 | 03:44 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I just wet it with a tad of coolant. Slides right on, doesn't come off.
And yes, make sure your spring is in the hose, unless your running a stainless hose that is.
Old Aug 31, 2020 | 09:48 AM
Mpls Funk's Avatar
Mpls Funk
Got it! Thanks to Tom DeWitt, he pointed me to Paragon and I now have the correct hose with a spring!
To Installing lower radiator hose
