Drive Shaft remove/install
Old Oct 28, 2020 | 09:32 AM
BKbroiler's Avatar
BKbroiler
Originally Posted by hgoodwiniii
Hi everyone. I am ready to install the main driveshaft in my 76. I messed up and did not mark (or accidentially painted over the mark ) which end goes to the transmission and which goes to the differential. Mine has about a 1" by about .25" raised metal area on one end which I assume is a weight. Is there anyway to figure which end goes where at this point? Thanks
The driveshaft can be installed in either direction. That is a weight that you are referring to but it doesn't change the orientation.
Old Oct 28, 2020 | 09:56 AM
hgoodwiniii's Avatar
hgoodwiniii
Old Oct 29, 2020 | 07:05 AM
2mnyvets's Avatar
2mnyvets
Originally Posted by HMFIC1
I’m still struggling with the fact I could not get the joints to clear the yokes with the caps on. I’m guessing another 1/4 - 1/2” is all it needed.
If it is any consolation, I had the same issue with my 73 BB 4spd. I spent days measuring and comparing it to my 69 350 Auto. I didn't find any significant difference, but I was using a tape measure and it was difficult. I was in the midst of a frame off so I spent the effort to move the engine front 1/4". The other option I had was to shorten the drive line.
Old Feb 8, 2025 | 03:01 PM
mad4slalom's Avatar
mad4slalom
Everyone thanks for the all replies and guidance (keep them coming). Going to order up the u- joints and give it a go later this week. Some good suggestions here to hopefully make it easier. And —- btw —- hats off to anyone who has replaced that pinion seal from the ground!! I have a lift and would not have attempted it without.
I did my seal and tailshaft bush , no puller so got in there with a small air saw, had’nt even cut halfway through and she popped right out with the vibration of the saw !👍
