No Power in 79 Corvette
Old Sep 14, 2020 | 07:15 PM
TraciA's Avatar
TraciA
4th Gear
Default No Power in 79 Corvette
I drove the vette around town and then 2 hrs. later, it would not start. No crank, no windows, no horn, no lights. I replaced the battery and still nothing. This is the first vette that we have owned and do not know what our next step is to fixing this problem. Any suggestions are greatly appreciated.
Old Sep 14, 2020 | 07:51 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
Check the 'fusible link' down by the starter.
Old Sep 14, 2020 | 09:42 PM
gdm78vette's Avatar
gdm78vette
You might want to check the frame ground connection as well. It's on the frame under where the battery box is.
Old Sep 14, 2020 | 11:02 PM
dshawster's Avatar
dshawster
Old Sep 15, 2020 | 12:09 PM
TraciA's Avatar
TraciA
4th Gear
Thank you for your input, this is a nice forum to belong to and I have learned so much in the last few days! We are thinking that it is electrical, so we will be starting with the ground wires to make sure they are connected. If so, then it is on to the fuse links. Hopefully we can trace the problem. I am looking for an electrical diagram today.
Old Sep 15, 2020 | 01:12 PM
Peterbuilt's Avatar
Peterbuilt
https://docs.google.com/viewer?a=v&p...TYyNWViMWY1NzY
Old Sep 15, 2020 | 03:02 PM
7t9l82's Avatar
7t9l82
Originally Posted by dshawster
Old Sep 15, 2020 | 10:12 PM
righthanddrive's Avatar
righthanddrive
Check the terminals on the battery. They may be loose/corroded
Old Sep 16, 2020 | 12:34 PM
TraciA's Avatar
TraciA
4th Gear
Thank you for the diagram.... will be working on this problem later today. Will keep you updated!
Old Sep 16, 2020 | 06:18 PM
bradleyb66's Avatar
bradleyb66
Don't just check that they're connected - remove the bolt from the frame, clean all surfaces on the frame, bolt, and cable, then re-connect.
Old Sep 16, 2020 | 07:12 PM
7t9l82's Avatar
7t9l82
The 79 and other years had an aluminum ground cable and they are garbage. Don't waste your time with an ohm meter and playing around, CHANGE IT! They will cause you trouble.
Old Sep 21, 2020 | 02:46 PM
TraciA's Avatar
TraciA
4th Gear
Thank you everyone for your suggestions! We found the problem, there was a loose wire going to the starter! Tightened it down and all is well with the vette! This is a great forum!
To No Power in 79 Corvette
