Fuel/exhaust smell
Old Sep 20, 2020 | 09:10 AM
kodpkd's Avatar
kodpkd
Default Fuel/exhaust smell
68 327 350 hp, holley spread bore carb, stock side pipes. Since I got the car, when driving you can smell the exhaust a bit. Sitting in the garage you can smell gas or exhaust. Is this just the nature of the beast? Did they do this when new? I'm going to do a check of the exhaust system from the manifold to the end for leaks. After that I'm sure it could be a 1000 other things.
Old Sep 20, 2020 | 09:47 AM
interpon's Avatar
interpon
Not sure exhaust would matter if leaking or exiting correctly when pulling in garage..
i would inspect fuel lines and nose finger wipe smell test..
then the 1000 others..
i thought mine smelled of exhaustand gas and was sneaky leaking gas lines that were not visual..no more smell...
Old Sep 20, 2020 | 10:35 AM
MelWff's Avatar
MelWff
What color is the side pipe outlet, black or beige?
Old Sep 20, 2020 | 12:27 PM
kodpkd's Avatar
kodpkd
I would say they are both pretty black. I suspect the engine is original and might be burning a little oil, but not sure if this would make it smell. I have done work on the gas lines and didn't think they were leaking. I can check again.
Old Sep 20, 2020 | 01:46 PM
MelWff's Avatar
MelWff
The black could also mean rich which would account for the smell.
How is your timing set, just to stock, more advanced, recurved?
Is your vacuum advance connected to manifold or ported?
Exactly what list# carburetor?
Do the idle mixture screws when turned clockwise cause a drop in idle speed and eventually stalling?
Stock cam?
Old Sep 20, 2020 | 01:57 PM
ctmccloskey's Avatar
ctmccloskey
I was having issues with my 1968 C3's 427 smelling rich at times so I installed an Air-Fuel Ratio gauge. This helps you really get the most out of the carburetor as you can see just how it is running.
My C3 has a Vented gas cap which will release fumes and in a sealed Garage you will smell gasoline, not the garage has ventilation to avoid that issue.
The combination of the the 1968 with the 327 is probably my favorite revving engine built by GM.
Old Sep 21, 2020 | 09:10 AM
SVASSH's Avatar
SVASSH
St. Jude Donor '21
I have a new to me 74 with a rebuilt engine. Had the same issues with exhaust and gas smells. With a car this old things naturally shake loose. I tightened down exhaust manifolds, oil pan, fuel lines etc. All helped but what helped the most was setting timing properly. Still some exhaust smell because we have no cats but not overbearing like it was.
Mine was set at 0 degrees initial timing.
Old Sep 21, 2020 | 09:21 AM
kodpkd's Avatar
kodpkd
Stock cam?
My timing is set to Lars spec. It has done the same thing before and after setting the timing.
Vacuum advance to manifold.
4175 Holley
Yes the metering block screws will cut the fuel off, set to about 1 1/2 turns out to max idle vacuum.
Stock cam.
I think I will check the exhaust bolts to the manifold.
Old Sep 21, 2020 | 11:17 AM
MelWff's Avatar
MelWff
What is the list# of the 4175, that is the model #.
Look at the front of the airhorn.
Using Lars set up what initial timing are you running?
You confirmed that the vacuum advance works?
Old Sep 21, 2020 | 01:25 PM
kodpkd's Avatar
kodpkd
0-80555C carb.
Vacuum works!
I'm not exactly sure about the timing. What ever Lar's said. I think 25* initial.
Old Sep 22, 2020 | 06:56 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Sounds to me like it smells like a Car! Bloody oath. It runs on gasoline and makes exhaust. Harden up princess!
Old Sep 22, 2020 | 11:26 AM
MelWff's Avatar
MelWff
If the exhaust outlets are black it's running rich but hard to pinpoint why since timing and carburetor seem correct.
Have you ever tried adjusting the mixture screws based on getting an rpm drop and then backing off rather than using a vacuum gauge?
Old Sep 22, 2020 | 08:04 PM
kodpkd's Avatar
kodpkd
I could try to adjust it a bit. What about the primary main jet, and power valve?
Old Sep 22, 2020 | 08:19 PM
MelWff's Avatar
MelWff
The main jet ,if the carburetor hasn't been modified is a 62, and should be fine. The power valve, 6.5, isnt blown since the idle mixture screws effect the idle as you turn them in.
You can't check the float level unless you remove the bowls.
Do you notice gasoline dripping down the carburetor throat at idle or immediately after shut off?
Old Sep 22, 2020 | 09:43 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
RE: the smell while in the garage
Can you better define what you smell? Raw gasoline or car exhaust?
Exhaust smell is likely a condition of less than complete burn of the fuel - very carbon black, sooty exhaust pipes and spark plugs. Full tune-up to solve issue.
Raw gas is probably a leak somewhere or a poorly sealing gas cap. Check every connection fitting for fuel stains. Even though you have a vented cap (or should, in a stock '68), the cap gasket should seal against the filler neck.
Also, keep in mind that these cars do not have the emission controls that modern cars have. Their gasoline burn efficiencies are much less complete and will generate a higher degree of "ambient" fuel/exhaust smell - but it shouldn't be so strong as to force you from the garage or cause health concerns over the vapors you're breathing.
Old Sep 23, 2020 | 07:46 AM
augiedoggy's Avatar
augiedoggy
It also doesnt help if the charcoal canister is disconnected im told (which was long gone on my 74 when I got it).
Old Sep 23, 2020 | 09:29 AM
kodpkd's Avatar
kodpkd
I am at 5000 ft. maybe my main jet should be different. The float has been set. I have been through the gas lines and gas cap, no leaks that I can find. I'll look into the carb throat. I guess I shouldn't see fuel dripping.
It didn't come with a charcoal canister.
To Fuel/exhaust smell
Old Sep 23, 2020 | 03:02 PM
MelWff's Avatar
MelWff
You didnt mention the 5000 ft altitude before.
if you still have a 62 drop it down to a 59, 60 largest.
Old Sep 23, 2020 | 03:47 PM
7t9l82's Avatar
7t9l82
You may be right. People are so used to newer cars they forget how real cars smell. Something could be out of whack but then again it may be nothing
Old Sep 23, 2020 | 06:37 PM
kodpkd's Avatar
kodpkd
I'll have to check. I think I installed a 58 jet.
