Catastrophic Water Pump Failure
Old Sep 26, 2020 | 09:56 AM
cv67's Avatar
cv67
St. Jude Donor '05
300 for a mech fan that is just stupid, wow..Can aftermarket fans be setup to use with a clutch?
I used to use a flexalite nylon fan (weighs a few oz) moves tons of air and isnt noisy..will never break.
Cant help but wonder how that would play with a clutch. You could run rpm and never worry about all that weight spinning on the water pump.
Old Oct 23, 2020 | 09:41 AM
2mnyvets's Avatar
2mnyvets
I want to close out this post with a final update.
Originally Posted by 2mnyvets
For the water pump I called zip Corvette and they told me that you could not put a shaft with a ¾” inch pilot into a casing that had a 5/8” pilot. .
This may be wrong. It looks like the 5/8" pilot is a 3/4" shaft that was cut down to 5/8" at the nose.
The difference between stage 1,2 and 3 are as follows: stage 1 has a cast iron body and cast iron impeller, stage 2 and 3 have aluminum casings and a stainless steel impeller. Stage 3 has a thicker pulley mounting flange.
I took the back off the Stewart stage 1 pump and it had a stamped SS impeller.
I upgraded the alternator to a 150 amp Powermaster alternator. I am not sure about adding a new ground. The alternator bolts to the block so that may be sufficient. I will measure resistance and decide whether an additional ground is needed.
The wiring resistance is so small that a conventional Ohm meter will not measure it. I added a new #6 ground and put external tooth washers between the bolts, alternator, brackets, and the block.
One item, the Dewitt radiator is smaller in width than the stock radiator and you need different rubber mounts when switching. They are not included.
Overall, it was an easy install and I am pleased with the results. The car appears to run at the 170F thermostat setting when it is moving, which is about 10F cooler than the stock radiator. And it will cycle the fans when idling. I won't know for sure until next summer whether the car has a cooling issue when it is hot and the AC is on.
