FINALLY Got it!! DD2000
Old Dec 2, 2002 | 11:24 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default FINALLY Got it!! DD2000
Just got my Desktop Dyno. Can't wait to compare it's results to one of our own DynoJet machines at http://www.thedynoshop.com :cheers:
Engine should be done this week !! :lol: :yesnod: :cheers:
DD2000 shows me at or close to 375HP @ 5,000 and 432 Foot Pounds of Torque at about 3500 :yesnod:
Hmm that otta make this Stingray move right along now!
<<This is gonna be a long week waiting to see it happen ...>>
[Modified by SanDiegoPaul, 4:25 AM 12/3/2002]
Old Dec 3, 2002 | 12:23 AM
QuickVet's Avatar
QuickVet
Default Re: FINALLY Got it!! DD2000 (SanDiegoPaul)
bout time :p:
Old Dec 3, 2002 | 01:09 AM
SanDiegoPaul
Default Re: FINALLY Got it!! DD2000 (QuickVet)
bout time
Yea I agree!! What He SAID!! :D
Old Dec 3, 2002 | 02:26 AM
ry's Avatar
ry
post pics when you get it running. congrats
Old Dec 3, 2002 | 11:00 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i have an experiment if your interested. i just overhauled my engine about two months ago and 'tested' it with a g-tech. i'd like to compare my results with what you get on the DD2000, then compare how accurate the DD2000 is to your dynojet machines. let me know if your interested and i will supply all the known stats on what i did.
Old Dec 3, 2002 | 11:34 AM
SanDiegoPaul
Default Re: FINALLY Got it!! DD2000 (clutchdust)
Sure... Why NOT?? The results I got so far, with the two engines I've tried it on are right in the ball park with expectation. Let me know :cheers:
Old Dec 4, 2002 | 12:27 AM
IronJen's Avatar
IronJen
Abby Normal
o.k. paul. this is what i have:
standard 350 bore & stroke with four valve relief pistons
cam is 204/214* with 114*LSA .420/.442 lift, installed straight up-ground 5* advanced
heads are 305HO with 1.85 intake/1.5 exhaust 58cc
intake is factory aluminum and factory q-jet
shorty headers 1-5/8" primary with 2-1/2" collectors. pipes neck down to 2-1/4" w/flowmaster 40s
jacob's pro street ignition
don't know if that is enough information or what else you might need. i figure a compression ratio would be nice but i don't know what that is either. i'm guessing 9.2-9.5:1. stock, it was something like 8.2 with 76cc heads so i think the 58cc heads would be worth nearly a full point or more.
let me know if there are any other specifics that you need and i'll see what i can find out. thanks
To FINALLY Got it!! DD2000
