71 How to remove lower dash pad
Old Sep 23, 2020 | 06:12 PM
kissarmy007's Avatar
kissarmy007
Default 71 How to remove lower dash pad
Hello, I’m trying to remove the lower dash pad on my 71. I removed 7 screws 3 on the top 2 on the door side , 2 on the gauge side still wont move. I removed the vent handle so I think I missing something that is holding it in. I removing it so I can get access to the nuts that hold the bezel to the console ,so I can remove my oil pressure gauge. Thank you in advance for your help...
Old Sep 23, 2020 | 07:29 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Assuming you're talking about the passenger side: then you need to remove the lower kick panel. once it's out you'll have room to drop the dash pad down and out from under the upper dash without breaking anything.
So, remove the door sill plate then the kick panel.
Old Sep 23, 2020 | 11:18 PM
Eliredandblack's Avatar
Eliredandblack
You will better off by loosing the screws holding in the console first. If your console meets up with the gauge cluster, you don’t want to brake the 40 year old plastic/vinyl tips.
Old Sep 24, 2020 | 01:34 PM
pspicci's Avatar
pspicci
i have a 71 and you should not have to remove the sill plate or the kick panel to get the dash pad (with the pockets) out of the car. if you remove the little square panel by the front of the center consol that may help but all you should have to do is remove the 7 screws you mentioned and the pad should come out.
Old Sep 24, 2020 | 01:59 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I think I missing something that is holding it in...
Possibly the ducting behind the vent ball.
Old Sep 24, 2020 | 04:05 PM
kissarmy007
thank you everyone who answered my post,I will try to remove it again. I’m thinking that it my be the vent that holding it up , not sure.
Old Sep 24, 2020 | 04:39 PM
carriljc's Avatar
carriljc
On my 68 I remove the sill plate and the lower kick panel--- I don't see it coming out easy without removing those......it helps avoid breaking things. It's easy enough to do and it's gentler on the old parts.
Old Sep 24, 2020 | 05:00 PM
kissarmy007
After looking at it closer , I had to remove the sill and kick plate and the lower dash pad came right out. Now my other problem is I’m trying to remove the nut that holds the gauge cluster to the console it’s giving me a tough time.
Thank you again to everybody who answered my post
Old Sep 24, 2020 | 05:04 PM
Hammerhead Fred
Well the good news is you're likely the first person to remove the cluster as those two lower nuts are seldom reinstalled.
Bad news is those two nuts are difficult to access and only allow short turns of the wrench.
They will be an exercise in patience.
Be VERY careful raising/removing the center cluster after you remove those nuts as the studs can easily rip/tear the vinyl on the center console.
Helps to put a towel over the center console to protect it while you're working.
AND be very careful you put NO pressure on the upper section of the cluster else the wiper switch area will snap off from the gauge section.
Old Sep 24, 2020 | 05:47 PM
kissarmy007
Can a socket be used or open end wrench. What is the tool choice for removing these nuts.
Old Sep 24, 2020 | 06:13 PM
carriljc's Avatar
carriljc
I suggest dropping the radio "back" (away from from the bezel, or really forward) and then you should be able to reach and access the nuts. Replace them with long nuts and buy a little ratching wrench to reinstall. I'll see I can find a picture..... gimme a few...
Old Sep 24, 2020 | 06:16 PM
carriljc's Avatar
carriljc
here, eyeball this.... https://www.corvetteforum.com/forums...post1598456191
more pointers therein also..
I use a ratching open end wrench to install and remove since I installed the "rod coupling nuts" put on there..... before that, for ages, I didn't even have those 2 lower nuts installed. https://www.harborfreight.com/hand-t...-wrenches.html
Old Sep 24, 2020 | 06:28 PM
carriljc's Avatar
carriljc
FYI - here is the latest USB/Aux Input stereo I put in my car when my last cd player failed. No depth so it's real easy to reach those little nuts now from the side now. It's a cheap one that I just put in to see if I like it but it's worked fine so I've kept.... I'll replace it with another better quality one someday ..... it was like 22 bucks so no-harm, no-foul.
Old Sep 25, 2020 | 08:44 PM
kansas123's Avatar
kansas123
Some have used 1 or 2 extensions and deep socket to remove those nuts. You gently pull the bottom side of the console out and work the extensions/deep socket up the tunnel to reach the nuts that way.
To 71 How to remove lower dash pad
