Turn signal electrical problem
Old Dec 3, 2002 | 09:38 AM
Duke94's Avatar
Duke94
Default Turn signal electrical problem
When I turn the headlights on, the left turn indicator light (green one on the dash) stays on. Also, the left front turn signal does not work and the bulbs are ok. I assume I have lost a ground someplace, where would it be?
Old Dec 3, 2002 | 10:09 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: Turn signal electrical problem (Duke94)
Check the connection in the headlamp area. I had the same problem last spring and it went away after I cleaned the contacts. I also checked the contacts at the flasher under the passenger dash (in front of the right knee.) Good luck!
Old Dec 3, 2002 | 10:42 AM
Lil_Vette_Chic's Avatar
Lil_Vette_Chic
This is so funny, mine started doing that same thing this weekend. It was working just fine and then I decided to change out the lens cause it was cracked. That was all I did, I didn't mess with the bulb, and now it only works with the headlights off. Must be the connection at the signal light. Good luck with yours.
To Turn signal electrical problem
