Is the holley worth it?
So eight months ago I bought a remanufactured Qjet from Ecklers and now it's doing what all reman Qjets do. It's running way too rich and I would really like to switch to either a proper Qjet or a Holley instead of rebuilding it. I don't think I can even find a rebuild kit since I have no idea what kit even fits it
I'm currently in between two choices (I'd rather go with the 2nd choice):
1. Buying a brand new Holley spread bore 650
2. Spending less on a very well done Qjet
The Holley carb is ~$650 which is a bit excessive considering that I have to tune it and redo the brake booster connection and probably the fuel line
I don't have the experience or time to research and buy a correct Qjet core and build it all the way up from the ground so that's also why a brand new Holley seems like a good choice. Again, all I'm looking for is something reliable.
I rebuilt the previous carb that was in my corvette which was a horrible reman carb from a checker bus so I know the basics when it comes to Qjets so tuning it would be easier.
I don't know where to find a good quality remanufactured or rebuild Qjet the best-looking one I've found is a 7042202 carb for a 1972 corvette, my car is a 71 but it has a 5/8" fuel line on it so the later carb makes it so I don't have to replace it
https://quadrajetpower.com/chevrolet...rajet-7042202/
I don't know if these guys are any good and if anyone knows where I can get a really good quality Qjet please let me know
I'm willing to pay the difference if it means my carb will last
OP maybe your plug on your quadradet is leaking, epoxy that sucker shut and use it?
Both are reliable carbs imo hard to go wrong eithe rway. I used to have a holley spreadbore on my Camino, DD it for years never once touched it. Same for the dailies that used Qjets...todays Holleys are pretty good they dont need fooling with all the time like the ones of the 70s/80s
https://www.ebay.com/i/312993472038?...gaAtEsEALw_wcB
The first is a 77' 350 L-48 carb and the second was a real score, a 1906 Edelbrock in almost perfect shape. If you look.....they are out there.....and would be what I would do. Q-Jets still have a stigma to the uninformed....therefore the only people that are buying them are knowledgeable hobbyists who know what they are looking at......a quick search found this: https://www.ebay.com/itm/1978-Chevro...QAAOSwa5ZfQVmQ all it needs is the accel pump lever.....which you have
The first Q-jet I bought sat on the shelf 60 days before it found a home on a 72' 350/200........I am keeping the Edelbrock for myself unless someone had to have it.....
The Holley works very well......a lot of people use them with great success, but the cost of admission is high, and I do not believe they are as responsive off idle.
Good Luck on your search....
Jebby
It all depends on how many internal parts like rods & jets & hangers got mis-matched during the rebuild.
It might be a simple fix... or not.
A well running Q-Jet is an excellent carb, and very dependable. Just not the easiest thing to tune yourself.
On the GM spreadbore Intake plenum as you know, are two small primary holes that match the QJet throttle blades.
At the rear of the plenum is is the larger holes "spread" out.
But the real story here is the bolt pattern or the carb stud locations. That is what diffiates QJ spreadbore from Holley Squarebore, the bolt pattern.
Google: pictures of Edelbrocks 2101. This will show the plenum and optional bolt patterns.
After a thorough cleaning and lowering the float level a tiny bit, I'm hoping the carb is going to stop gushing fuel out the top like a water fountain. I'm not sure a rebuild kit will do much because the components inside have only seen 8 months of use and look pretty new
I read through Lars' tuning guide for Qjets and he mentions that starting off with the stock rods and jets for your current serial number carb is a good starting point. I'm hesitant about doing this because the stock tune for my 1987 GMC truck carb is very lean compared to the 1971 corvette carb
What do you guys think about tuning the 78 truck carb with the same or very similar-sized rods and jets as the 1971 carb and using that as a starting point?
Of course, I'll have to buy 1975 and after primary rods due to the size difference.
I saw somewhere that you want to tune carbs to be slightly richer than the stock tune because modern fuel burns quicker or something like that. Can anyone confirm if this is true or just bs?
That makes the most sense to me and currently, I have no idea what's in the carb because the primary rods have no size markings and the markings on the jets are illegible.
The secondary rods are good and the power piston spring should be but ill get a few if I buy new rods and jets.
