Tachometer cable lengths??
Old Sep 28, 2020 | 11:15 AM
Daveinspain's Avatar
Daveinspain
Obsessed
2025 C3 ('68-'73) of the Year Finalist - Unmodified
Default Tachometer cable lengths??
I guess I need a new tach cable, while trying to order one I see there are different lengths. I have a 1971 base 350/270hp automatic coupe. They offer a 22 inch and a 40 inch, I think there is a smaller one too, maybe a 7 inch. I suspect I need the 22 inch which seems about right. Just want to make sure before I order it. Also going to get a new drive gear. Can I get just the drive gear or should I get the full kit. Drive gear alone is like $39 full kit is $98...
Old Sep 28, 2020 | 11:25 AM
71chimera's Avatar
71chimera
cable manufacturer
http://www.clarkbrothers.net/speedom...er_cables.html
Old Sep 28, 2020 | 12:53 PM
Daveinspain
Obsessed
Originally Posted by 71chimera
Hi and thanks, but I’m not sure how thIs helps me. The link takes me to a page and a chart talking about truck cables... Do they also have Corvette tachometer cables. I figure the must be a standard size for the year and model of my car, plug and play...
Old Sep 28, 2020 | 01:16 PM
71chimera's Avatar
71chimera
not just that page
look around the site, they have cables sized to fit anything
Old Sep 28, 2020 | 01:29 PM
71chimera's Avatar
71chimera
cable catalog
even has ALL the bits to make a cable
but No, they don't list them for corvette but they list by dimensions, tip type, thread etc etc
http://www.clarkbrothers.net/pdf/MC794_CBI_Master3.pdf
Old Sep 28, 2020 | 02:03 PM
MelWff's Avatar
MelWff
Where are you seeing 40" tachometer cables?
The Corvette vendors all show only a 22" tachometer cable.
Old Sep 28, 2020 | 02:23 PM
68/70Vette's Avatar
68/70Vette
What is a "new gear drive?" The tach cable clips into the tachometer housing cannister and the other end screws into the distributor tach drive. This is the stock, factory configuration. I'm aware that there is a 90 degree tach drive iadapter than can be screwed into the distributor allowing the tach drive cable to mate to the distributor at a 90 degree angle. Apparently some people find this as a more conventient way to link the tach cable to the distributor. Is this what you are describing?
Old Sep 28, 2020 | 05:27 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
my 68 uses the 22 inch, Im sure yours is the same
To Tachometer cable lengths??
