75' Power Window Relay
Old Oct 18, 2020 | 12:30 PM
Snackpak's Avatar
Snackpak
8th Gear
Default 75' Power Window Relay
Isolated a power problem and fixed that yesterday to get the car started, was an in line fuse. Everything working except the both windows. Checked the radio fuse - good; put in a new pwr accy breaker - nothing. Located the power window relay, pulled the wires, checked for voltage both with car off and then with car on, no voltage, should there be? Before I buy a new relay to install. What might be a new check prior to replacing the relay? Perhaps the new pwr accy breaker is not properly seated?
Old Oct 18, 2020 | 01:02 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
https://docs.google.com/viewer?a=v&p...WRiNTdjNjdkNTQ
Is the pink/black wire plugged in the fuse box?
Old Oct 18, 2020 | 02:05 PM
Snackpak's Avatar
Snackpak
8th Gear
I will verify, what happened was we were raising window at same time turning headlights on, car died, all systems, nothing. Found the circuit breaker for headlights, replaced and the car and all systems except the pwr windows are working. Had read a 2009 post on the subject which led me to check the radio fuse and find the relay under the shift console.
Old Oct 19, 2020 | 02:56 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
See if this helps you figure it out.
Old Oct 19, 2020 | 10:01 PM
Snackpak's Avatar
Snackpak
8th Gear
I will step through this before ordering any parts, thank you!
Old Oct 24, 2020 | 05:37 PM
Snackpak's Avatar
Snackpak
8th Gear
Default Wires
So the pink is not plugged into the fuse box, nor the orange, nor the red.
Exactly which fuse does each color plug into?
To 75' Power Window Relay
