Prep for Pulling Engine + Engine Bay cleanup
I am about ready to pull the engine & tranny out of the 79 in the next few weeks. The plan outside of rebuilding the engine & adding an overdrive tranny is to 1. Tear apart the front suspension, clean, paint and replace rubber/parts as needed. 2. Clean up the frame & engine bay as much possible. 3. Likely replace the decrepit wiring harnesses for new ones from Ecklers / Lectric Limited
My question for those who have done an engine bay restoration:
1. What did you do to keep things organized when taking things apart? Bagging and tagging hoses, etc?
2. What do you wish you did differently?
3. What were the biggest challenges?
4. My power steering components don't seem to be leaking...but they are 40 years old? Should I spend a little money and replace this to ensure another 40 years of good steering?
Thanks!
Ian
Id take some good pictures as you go along they are great to have during assembly.
Did the bag/tag thing, months later I was glad I did, forgot where half the stuff went.
Nothing worse than putting something together not knowing what goes where or worse losing small pieces.
were they came from. You can right left side or right side to explain
Also good for taking out screws in the interiour, makes it easier to put them back in the correct location.
I have a bad memory so this helps me after many weeks.
It would be a good time to replace the positive battery cable if it has never been replaced. Don't know about your '79 but my '73 had a copper clad aluminum cable that was showing signs of corrosion inside the jacket. I built a new all copper cable when I replaced my engine and transmission earlier this year. One thing to think about if you build your own positive battery cable: Leave extra length and don't terminate the starter end of the cable until you have your engine and headers in place. I terminated my cable early in the process and while I made it work, the cable was too close to the new header for my comfort. I ended up running the cable to a terminal post I installed on the lower passenger side firewall and then routed a short cable from there to the starter so I could keep it away from the header.
DC
...or in my case, many YEARS!!!
Paul
