Alignment experts please check my sheets
Before
After
Right front
Left front
If you are going to autocross it that's different.
Caster is even, but toe-in is high.
Even thrust angle is good.
Shim packs are pretty even.
Large camber and large toe-in will wear the inside edges of the tires, and you may get cupping wear.
I would never use the alignment specs built into a machine. Those are for skinny 1972 Bias Ply tires, not modern rubber. These are excellent and are either from VBP or Van Steel, and vary by intended useage.
Personally I would go lower on the camber, like .5 degrees for the street. No need to go lower, there is no effect on wear with radials.
I would go for much lower toe-in in the front, that's an 1/8" I'd go almost to zero.
Rear toe I would leave at 0.14 (1/8") after they re-do the camber.
Now for the set-back issue:
With all your new parts I would expect it to be one of two things: 1) a bad a-arm or 2) bad alignment setup & calibration
0.3 degree setback is 3/8" back at the wheel. If the wheelbase is really off that much you can measure it with a tape measure. Your printouts say it is 0.6" longer on the right. I would verify this. If it is true, and only if, then I suspect one of your a arms is the cause, It's 3/8" off. And that seems highly unlikely. But if it is that far off it should be easy to find.
My opinion of many alignment shops is not too good, because a lot of them depend on the machine, and do not understand the basics. Unless you go to an old-school guy with a lot of experience. You do not need a $50k machine to do an excellent alignment. Tape measures will do. If they are good enough for Penske's winning 200 MPH Indy car they are good enough for me. I did my own Pro-Solo alignments for my race car for 27 years, sometimes weekly. Cargotzman has an excellent write-up in this forum on how-to.
Their printouts look very good except for the curious setback issue. Verify.
One last thought. Do you have the global west upper shafts with the slots for the mounting studs? If so the alignment guy would never in a million years expect to look for them and could have one slid forward and one slid rearward. The shaft holes would look something like this: (I made my own)
Just to clarify, the 5 degrees of caster isn't the problem, it's figuring out why your upper A-arms are shimmed very differently, right?
Also make sure your tire pressures are equal on all tires and there is equal wear on the tires. If they are not equal both sides then there are problems with the frame / suspension / suspension mounting points.
But from the sheets displayed It looks like the car is not square at the axle points. For caster measurements this should not be a problem. Caster is the upper arm vs the lower arm. This can be only 2 items. The mounting points of the arms upper vs lower arm or the dimensions
of the upper & lower arms (bent). I would measure the distance of the arm lengths . Bushings to ball joint and compare passenger side vs driver side control arms.
Leigh, I don’t have the slotted cross shafts on my arms.
Oh and Bikespace, I do have a spreader bar. And it is very crooked as a result of the way the upper arms are shimmed lol!
Bill
I put 1/4" offset shafts in mine for that very reason, you could do the same. Then you could pull the camber out and keep your desirable 5 degrees caster. I know Global West has them. Initially I thought that was what you have, but yours look centered.
To me I would fix it. But I am OCD about suspension. Too many years auto crossing I guess. It will increase your tire wear. But with that engine I do not think that Front tire wear is going to be your issue anyway LOL!
Update: Just checked Global West they only have one type of upper a arm.
