trailing arm bushing
Old Nov 8, 2020 | 03:11 PM
69vette427/435's Avatar
69vette427/435
Default trailing arm bushing
Just installed new bushing on trailing arm. whet to spread the sleeve and it split on the end. Should I have used a press instead of big hammer? I do have the tool to install it
Old Nov 8, 2020 | 03:32 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
yes, you can buy or make a tool to press the steel sleeve. swedgeing the inner sleeve outwards. big hammer? sounds a bit crude.
Old Nov 8, 2020 | 05:00 PM
GTR1999's Avatar
GTR1999
I have seen the sleeve split like that and it happened while using a fixture on the press. The sleeves were the problem. I use a little grease on the flare tool and carefully press them in but use sleeves from one source that work.
To trailing arm bushing
