Oil Pump Priming Question
Old Dec 5, 2002 | 04:23 PM
conway62's Avatar
conway62
Default Oil Pump Priming Question
Is it possible to prime a new oil pump before bolting it to the engine? If so, what is the best way to do it.
Old Dec 5, 2002 | 04:26 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: Oil Pump Priming Question (conway62)
no, you need to install the pum and the oil pan and then buy a priming shaft for about 15 bucks, then use a drill motor and prime the pump till you see and feel that the pump is pumping. I think Mr. gasket has one at most auto supply stores.
Old Dec 5, 2002 | 04:28 PM
71roadster's Avatar
71roadster
My machinist just told this morning to pack the pump full of vaseline before I prime it. I had to do this before on a chevy V6 I had. Old old trick.
Chris
Old Dec 5, 2002 | 04:39 PM
redwingvette's Avatar
redwingvette
Default Re: Oil Pump Priming Question (71roadster)
I just fill the pump with oil even though it runs back out when you flip the motor over. Then I use an old distributor (with the gear ground down) and a drill motor before I install the distributor and start it up.
Old Dec 5, 2002 | 04:44 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
What you do is pack it with light grease. Pull the cover and pack the gear area with Vaseline or light bearing grease of some kind. It will start pumping immediately.
Old Dec 5, 2002 | 04:45 PM
Paul L's Avatar
Paul L
I took a different tack with my oil pump project. Removed the hot wire wire from the HEI distributor, cranked the starter until I saw pressure on the oil gauge (about 20 seconds), reconnected the hot wire and fired up. Worked.
Old Dec 5, 2002 | 05:01 PM
SanDiegoPaul
Default Re: Oil Pump Priming Question (paul79)
Looking at that pic I'm amazed it worked! Did you put the oil pan back on first?? :lol: :lol: :lol: :lol:
Old Dec 5, 2002 | 05:12 PM
redwingvette
Default Re: Oil Pump Priming Question (SanDiegoPaul)
Don't know how importatant is is to "prime the pump" but the purpose is to get oil into the bearings and lifters so the engine doesn't star up when anything is dry. "The worst thing you can do to a motor is start it up" so once you start it you should never shut it off. :lol: :lol: :lol:
Old Dec 5, 2002 | 06:36 PM
Chris O''s Avatar
Chris O'
:iagree:
Completely eliminates the risk of pumping air and no oil.
:cheers:
Old Dec 5, 2002 | 06:49 PM
Paul L's Avatar
Paul L
Yes, it was a beer-after-the-work-is-done project ;) . The FelPro one-piece gasket was on and the oil filter in place.
[Modified by paul79, 7:02 PM 12/5/2002]
Old Dec 6, 2002 | 10:07 AM
john's '81 mouse's Avatar
john's '81 mouse
Quote: "Is it possible to prime a new oil pump before bolting it to the engine? If so, what is the best way to do it."
Answer: Yes it's possible, and in fact is recommended. As has been said, most engine rebuild instructions state to pack new oil pump with light grease or vasoline, then install pick up tube / screen, and then submerse in new / clean engine oil and turn shaft until oil is pumped up throuh pump and out the hole on top side of pump..........At least that's what I did when I installed new oil pump during rebuild of my 350.
Old Dec 8, 2002 | 07:17 PM
The Money Pit's Avatar
The Money Pit
Default Re: Oil Pump Priming Question (john's '81 mouse)
I just finished rebuilding my 406 for the second time because I didn't prime the engine before firing it the first time. I've built over a dozen engines before and never had one fail before.(I've used the pack the pump with Vasoline too.) The machinist explained why he thaught it failed.In my case the cam went flat,and the cam gets it's oiling from crank splash.The drill priming method insures the oil pump is primed and by pumping the oil up top before firing the engine,the cam and all valve gear get soaked with oil.
I wish I'd spent the $25. on the primer tool before the $1000. I had to respend. :U
Old Dec 8, 2002 | 08:27 PM
jackson's Avatar
jackson
Default Re: Oil Pump Priming Question (The Money Pit)
If you prime using a drill ... just remember correct rotation ... looking down onto top of pump (or primer rod) correct rotation is right hand (clockwise). Spinning motor with NO POWER to distributor works too ... we fire all race cars/trucks every time we crank in this manner ... spin starter until we see good op ... only then power-up ignition. Cam bearings are pressure fed. Cam lobes do get some lube from crank splash ... but the lifter bores are pressure fed and some of that oil gets thrown out & onto lobes also ... so long as lifters do not hang up in wrong position (as when a pushrod/rocker/valve stem bends or breaks.
To Oil Pump Priming Question
