Fuel Tank Question
Old Nov 18, 2020 | 12:18 PM
IDOXLR8's Avatar
IDOXLR8
Default Fuel Tank Question
In re-installing a fuel tank in a 68 Corvette, is it better to have the tank straps bolted at the rear a then hooking them to the front bracket then bolting the forward mounting bracket?
Old Nov 18, 2020 | 04:15 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
on my 71 I clipped them in then bent them around to bolt them on. I can’t see getting that clip in with them bolted in.
Old Nov 18, 2020 | 06:08 PM
theandies's Avatar
theandies
What does the AIM show? How did it come out? Do it the way the factory did it. I replaced my tank on my '71 years ago because of rust but I can't remember how the straps went. The AIM is your best resource for stuff like this.
Old Nov 18, 2020 | 08:42 PM
MelWff's Avatar
MelWff
On my 69 the rear adjustment bolts were fully loosened but still connected and the front brace was left attached.
Old Nov 19, 2020 | 12:43 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The factory had a massive advantage installing the fuel tank because there was no body on the chassis to get in the way or have gravity working against them. I don't think the AIM is going to tell you how to do it with the body in place; it'll just show you what parts are used to do it.
When I R&R'd my tank this summer, I clipped the straps to the support and then threaded the bolts once everything was in place and lined up. I agree with Sigforty - I don't think you'll have enough slack in the straps to have the bolt started and then hook the engaged in the support. When you get ready to put it all back up in there, get yourself another pair of hands - they'll come in real handy dealing with the gravity issue while the support bolts are started.
Old Nov 20, 2020 | 12:59 PM
mrvette's Avatar
mrvette
I dare anyone to do it with a full tank of gas.......
To Fuel Tank Question
