Baer 6P on a C3
Old Nov 22, 2020 | 06:43 PM
Dyaw's Avatar
Dyaw
4th Gear
Default Baer 6P on a C3
Came in possession of an 86 that has 14” Baer 6p’s front and rear with 500 miles on them. The car is trash other than the rims and brakes. Is the juice worth the squeeze to put them on my 1970?
Old Nov 23, 2020 | 12:14 PM
Corey_68's Avatar
Corey_68
That's something only you can decide, of course you'll have to factor in larger wheels if you already do have a set that will accommodate the larger setup.
I have no problem locking up the brakes with my 4-Piston Wilwoods, but if you are running the stock setup if maybe worth if you can justify the expense.
Old Nov 28, 2020 | 10:24 AM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
PM sent
To Baer 6P on a C3
