All-
i have an AIM manual, and I just can not seem to find the location at the firewall where the Speedo cable routes through. When I purchased my vette, the speedo and all related components were literally ripped out, so this has been an investigation for a while. I had the full dash ripped out to try to find it to no avail. Any ideas?
On page UPC 12J Sheet 5 W/O Cruise or the M20-M21 or M38-M40 transmissions or Sheet 5.1 W/Cruise you will see the speedometer cable (Shaft Asm) and grommet.
If you're missing the grommet Willcox Corvette should have it in stock.
Grommet Link: https://willcoxcorvette.com/corvette...correct-63-108
Thank you so much for the quick reply. I did have the grommet. Didn’t fit right, but I will get it in the firewall somehow. I appreciate the fast response! The hole was hidden behind the fuse box and under cables in the engine compartment.
