Re o ring caliper?
Old Nov 29, 2020 | 07:39 PM
busynick's Avatar
busynick
Default Re o ring caliper?
did o rings/piston/springs seals on calipers 10+ years ago, they were from CSSB, got new o rings/seals this week from sponsor here and the new ones are larger/thicker.
the pistons with new o rings are tight and no retraction with springs?
is that normal?
thoughts?
82 vette
Old Nov 29, 2020 | 08:47 PM
Duane4238's Avatar
Duane4238
Did you replace just the o-rings and not the pistons? I did mine recently and also noticed the o-rings, which were a red silicone material, were much fatter than the black ones I've seen. I also replaced the pistons and springs. I'm wondering if you have to use a new, appropriate piston with a new o-ring. Maybe check with whoever you bought the o-rings from.
Duane
Old Nov 29, 2020 | 08:49 PM
MelWff's Avatar
MelWff
Sounds like you need to order new pistons that match the O rings.
Old Nov 29, 2020 | 08:58 PM
busynick's Avatar
busynick
no ad's says anything about different types of oring pistons.
Old Nov 29, 2020 | 08:59 PM
busynick's Avatar
busynick
just new orings/dustcover....do you like the silicone seals?
Old Nov 29, 2020 | 11:26 PM
Duane4238's Avatar
Duane4238
The silicone o rings and new seals were just fine. Went right in with no problems and no leaks. I don't use the car much so thought the o rings would be a good choice from everything I've read here.
Duane
Old Nov 30, 2020 | 11:11 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I just did the Oring conversion from CSSB last spring.....they are still around. Maybe you should send the orings back and go with CSSB again
To Re o ring caliper?
