C-3 Chassis Flex
(copied text)
Ted Robertson, chief engineer for the Chevrolet SSR said: "A traditional stamped frame with this amount of strength and rigidity would weigh roughly 20% more than this one. That strength allows the frame to take on the road inputs, which lets the suspension do its job precisely."
Hydroforming is a process of shaping steel tubes through the application of water at extremely high pressure. It replaces traditional stamping processes, preserving more of the steel's strength and stiffness as it goes through the forming process. Hydroforming is done at low temperatures to retain the material's strength throughout the forming process, unlike high temperature processes which decrease material strength.
Hey Stingraycrazy can you open up another post and post up more pictures of your project? That looks SWEET!
Anyway, I've built my share of race-cars and if you have a problem with the frame tweaking than we "welded all the seams on the frame". I've seen my share of C-3 vette's and the spot-welds on the frame are nothing to smile at. Especially if your planning on driving the car like it was supposed to be driven then I would definately weld all the seams on the frame. If I remember correctly in the early 70's the racers would even weld gussets on the motor-mount brackets. :yesnod:
whew! sorry guys.
http://www.corvettecavalry.com/techp...-c5-frame.html
Kind of hard to get C3 frame look like that :crazy:
How about building C3 body on C5 frame. :cool:
Even better pictures of C5 frame here:
http://data.corvette.co.uk:8080/ecar.../c5chassi.html
[Modified by Hemmo, 10:57 PM 12/11/2002]
Dan
I am better at asking questions than I am at supplying answers. Many good points are being made and maybe we can learn from this brainstorming session.
I have looked at my old Chevy Power Book and reviewed how the roll cage is installed. The front or rear section I’m not really worried about, it’s the center. The way I see it the center is bridged with and 8 point cage. We will never be able to replace the structural strength it provides.
I wish I could get this spine in my tunnel I do think it would work, but How?
I can strengthen the front or the back, but how about the center? I think the X is definitely possible at least to some extent. I had wondered about a hidden cage that goes from the front door post hinges to the front bumper and from the back bumper to the main roll loop. But how can I tie them together through the door? Like someone above posted" Not even enough room for a cup holder."much less a roll cage in the passenger compartment on the street.
I thought about a rectangular Aluminum C Channel frame to go inside the door. One end attached to the upper and lower door hinges and the other end with a latch somewhat like the C-3 Convertible uses.
I considered using a piece of 1/4” Aluminum about 8” wide on both of the insides of the door forming a box to let the window operate. It would use however much lip space allowed to form a C-Channel on each plate.
I thought about this earlier in the thread when I was telling Stingray Crazy about the conversion kit for coupe to vert doors. The latch wouldn’t have to be in between the door and the pillar post like the Vert. It could stick out from the end of the door panel and mate with the female end extending from the Main Roll Loop at the rear side of the seat.
This is hard to describe. But all that would be exposed is the latch receiver at the rear of the door panel. It would probably only be a 1” in diameter and let the latch stick into the door maybe 2 ½ inches. The latch is round and tapers as it goes out. The door receiver is just the opposite. It would provide strength from any direction but out. The door striker could be supported by a side plate off of the Roll Loop to assist in retaining that. The weak spot then would be the door hinges or at least the bushings. Stainless Bushings?
Remember that no idea is a bad idea, because even a bad idea sometimes spurs the thought that creates the answer to a problem.
Thanks for all of your ideas. JIM
[Modified by PROSOUTH, 10:30 PM 12/11/2002]
I've been on the phone with him with the scan tool in my lap, trying to figure out what's going on. Really good people. :blueangel:
Anyway - I like this other concept of getting the front and back halves tied together via the door beam- I think it would have a similar affect as the 8-point. I've gotten so obsessed with this that when I'm driving to work in the morning, I sometimes go down the road with two fingers stuck next to a t-top guide pin at the center bar, to try and determine the direction of movement. It does feel like it's both ways, but I'm not sure. I might even put some plumber's putty at certain locations when I get a chance, to try and record the movement. (I never intalled my upholstery on the tops, I simply gave them a good paint job. I prefer the light weight and extra overhead clearance) I think the other C-5 related points are right on the money as well - the goal is to produce a rigid platform that we can utilize suspension components that do not have to compensate for excessive movement in the chassis, that will result in more precise performance without the need for excessive spring rates, etc. Anyway - love this stuff - It'll get me through the winter I think.
Ray. :flag
Gkull gave me a great Idea about a SFI flex plate shield and a tranny frame support. He suggested that I use an SFI shield for NHRA rules. I'll give it a try.
TPIShark I agree with you, this forum has given me so many good ideas. My wife thinks I'm nuts for sitting in front of the computer so much... Exchanging ideas and giving support to another member is worth it for me!
The Trans support will look something like this :crazy:
Hey Stingraycrazy, the engine plates will vibrate the same as solid motor-mounts. A buddy of mine has a vega with the engine plates and it's just the same as the solid motor mounts another buddy of mine has in his nova. :D
I can see an arrangement that uses an a-arm strut and bars that tie into the engine. Then a brace similar to clutchdust's at the bell housing with a spine that attaches to that brace and runs the length of the tunnel and ties into the rear end and frame. I think that would add quite a bit of stiffness.
anyway, from our perspective, that being a car that not only has been produced but is now long out of production and most corporate engineering is over, we have to weight certain aspects. what i call "s**t to worth" ratio. so far all the ideas here good ideas but have varying degrees of benifit and/or practicality. for us guys who are doing this stuff on the weekends in our garages, we've got to figure out what will provide max benifit for minimal cost and fabrication/manufacturing. sure, ultimately a c-5 style reinforced center spine would be excellent, however, how the heck are we going to put one in a c-3? the idea of the door brace is likely less effective but certainly more feasable. motor plates are not only feasable but on the market now, they have a downside by introducing a great deal of vibration into the car which some may not be willing to deal with.
so in short, we need to keep thinking. i'm sure there is a solution out there, we just need to figure it out. after all, if we don't, who will?
:crazy:
Dan http://www.vetteworksonline.com
I agree, I even posted this earlier. However I did propose to support the front pillar post with the front section of a roll cage going from the front bumper mount to the pillar post and then support the pillar itself with an additional verticle bar. Same in the rear except the Loop would catch the back kicker supports and then tie in the striker on the rear pillar post. But I do agree and was only trying to come up with something, and it did / does have a possibility of working.
Burners- A brace similar to clutchdust's at the bell housing with a spine that attaches to that brace and runs the length of the tunnel and ties into the rear end and frame. I think that would add quite a bit of stiffness.
I agree again, except I would not tie to the bellhousing unless absolutely necessary. If I did it would be with a Poly mount like I described earlier for the '55 style mount.
Ultimately a C-5 style reinforced center spine would be excellent, however, how the heck are we going to put one in a C-3?
Why not the same way as the '85? Why couldn't I run a 3x3 lightweight DOM Tube from the front frame dogleg all of the way to the bacK?
I believe I could make a transition from the front frame dogleg to just past the bellhousing that would allow my 3" exhaust run throuh it , then run the 3" square tube along side of the exhaust all the way to the rear crossmember.
I have no Clutch Linkage or Transmission Linkage to interfere. I could use about a 30" trans-member for the TKO to mount to with a passageway on the bottom to let the pipes go by or through. Then put two supports on each side between the original frame and the new spine. This putting a structural support about every two feet from the front crossmember to the rear.
Whew........................would it? JIM
