Spark Plug Analysis?
Dec 16, 2020 | 07:38 PM
Dec 16, 2020 | 07:46 PM
Cruise-In VIII Veteran
looks like rear cylinders are running richer than fronts, thats all. Stock intake manifold??
Dec 16, 2020 | 07:50 PM
Quote:
Originally Posted by
4-vettes
Stock iron manifold. Stock Q-Jet. Stock distributor.
Dec 16, 2020 | 08:53 PM
What manufacturer and plug number are they?
They could be too cold.
Dec 16, 2020 | 09:45 PM
MelWff
Autolite 24 in Dart IE heads. I am kinda concerned about the difference between #1 and 2 and the rest of them. That seems wrong.
Dec 17, 2020 | 02:57 AM
stock intake has the carb mounted off center. not thinking there's much you can do about it.
Dec 17, 2020 | 08:15 AM
Cruise-In IX Veteran
What carb are you running? What is your timing set at? Did you make a pass and then shut the car off to read the plugs? This link should help you with proper plug reading.
http://members.uia.net/pkelley2/sparkplugreading.html
Dec 17, 2020 | 12:04 PM
