Front alignment getting me crazy
- Camber L/-0.76 R/-0.77
- Caster L/1.86 R/-0.21
So Camber is not the issue, but I can't get the right caster in spec.
What do I see wrong :
- too many shims on the back bolt, about 3/4" where there's only a small one in the front
- wheel straight I can put 2 fingers between the back of the tire and the fender, I can put 5 in front of the tire/fender, that tells me the wheel is not centered in its weel, ok it could be body to frame alignment issues, but that is secondary for now, I need to get the proper alignment first then I'll see where it sits in the weel. If I were to adjust the Caster to be correct it would need the front ball joint to move even more backwards, moving the wheel even more backwards in the arch.
The fact that we can't get caster in spec and that I already have so many shims on the back bolt tells me I'm trying to chase a bottom ball joint that sits too far back for some reason.
So obvious would be "it hit a curb and that bent something backwards"
I managed to convince myself that the bottom a-arm pivot bar was bent, so I've ordered all the stuff and went for disassembly.. I can't see anything bent or out of shape..(looking at that MF of a bar I'm sure a lot of other things would bend before that) no wrinkling anywhere on the frame.. bushings were good (car was completely rebuilt in 2006, part of the rebuilt was a full front end fiberglass.. yeah I know how that sounds but show me where it's bent).
Also, front suspension stop bumpers have been cut down, so I guess this car might have been raced at some point.. gosh what were they thinking
Bringing the car to a body shop and have the chassis properly measured would cost around 2k where I live, a bit over what I think is reasonable to spend..
Any ideas what to look for next ? Anything I can measure myself to try identifying where is the culprit ?
I'll rebuild the lower a-arm with new pivot bar/bushings/ball joint, we'll see where that brings us, but given that the removed pieces looked good with no play/sign of wear I'm not optimistic it'll get better..
Really appreciate your help guys
this one has frame dimensions between the rails on the 79 sheet which is the same if i remember correctly. I had one for ealier years saved but cant find it
https://www.digitalcorvettes.com/thr...e-specs.87024/
Positive caster is what you want. It will make the car feel more planted on the highway. If the wheel is too far back in the wheel well, I'd look for a bent lower control arm, or bent mount, as @Jeff78 said.
I use SPC adjustable upper control arms, and you can really dial in a LOT of caster with them, but your problem is that the lower ball joint is to far back (aft).
Triangulate a bunch of random measurements on the bottom. Frame mounting holes to a-arm bolt positions, and ditto to lower ball joint. At an angle across the frame. The important thing is that both sides match (within 1/16") Something is around 1/2" off and it should not be too hard to find, tape measure is all you need.
BTW: I had my frame straightened 1 " for $300. $2k is ridiculous to just "check" it.
Here's a pic of the upper a-arm "tower" measurement that sometimes sags and a spreader bar can fix. 26-3/8"
Pictures:
Please forgive the gold.. it was the only colour in stock..it will be replaced at some point, also the piece of string is holding the caliper on the right where I removed the spindle/lower control arm..
You can see the control arm shafts are not the same.. the lower/new one has a bit smaller machined end on the right.. my car is 69, but is there any differences through the years ? Also the new shaft middle (black) portion extends couple mm's more on each side..
Can't see any obvious sign of damage..
First pic is taken from under the radiator looking at the forward frame extension
This is looking from under the engine towards the spring bucket, the bolt at the top is the rear control arm shaft bolt
Now from the right side looking in.. the green indent might be normal for the rubber stop.. its bend might have increased in the hit, the bend in the red circle is not there on the other side..
Comments welcome
So I see what you are getting at. It looks like evidence of an old front impact. If right side that could push the lower control arm back a bit.
My frame is currently vertical so I took a quick picture for you.
Measure from the lower control arm mounting bolt to a measuring hole in the frame on the other side. Sort of like the tape measure in my pic.
Then repeat on the opposite side. In an "X" pattern. Same spots. Your measurements should be exact (+/- 1/16")
With a front hit I would expect the frame to bend at the large "S" section and that would move back your lower control arm.
Keep at it you'll figure it out!
Your a-arm looks OK to me.
But to be sure just hold it up to the other one on the other side. If one of them is 1/2" off you'll be able to see it.
Also check that bracket where my tape measure stops, where the lower a-arm bolts to the frame. Sometimes they tear off and get re-welded. It could be on crooked.
If you need any more pictures or measurements let me know. My frame is clean and easily accessible, for now.
I would guess your "bump stop depression" is twice as large as mine. (Tried to get a similar angle).
I also do not like the fact that your two a arm crosshafts are not identical. One of them looks longerr as you describe That could possibly move the suspect a arm forward, or backward.
I see you have already removed the a arm bushings. Any pics? Could one of them have been very beat/compressed and caused the a arm to pivot? It would not take much at that location to move the ball joint 1/2". Maybe half that at the bushing. A beat up bushing could also be the whole problem and is a much more common wear item than a bent frame. KISS simple/obvious first!
able to make it correct.
duhhNow when I put the new bushings onto the new shaft and place it so one bushing touches the control arm outside face, on the other side the bushing flat is couple mm's from the arm.. picture :
Is that normal ? Would that be an indication my control arm has bent itself
If normal, How to I go about pressing the bushings as they will bottom the shaft before the control arm? or will the outter sleeve slightly compress the bushing and get flush with the arm ?
