Starter options, '69 350
Old Dec 21, 2020 | 10:31 AM
Corbis's Avatar
Corbis
Default Starter options, '69 350
I have a '69 350/350 (now a 383 stroker). Although I want to maintain factory originality, I do not like the crank sound of the starter; sounds like a truck starting.
I am considering the Hi-Torque starter from Corvette Central.
Can anyone recommend a starter?
Old Dec 21, 2020 | 01:09 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
CVR 5323. Best mini starter out there......buy it and be done forever. Read the reviews.....I have installed 8 of them and not a shim in sight.
https://www.summitracing.com/parts/cvs-5323
If you are still running points then you will need the 5323r
https://www.summitracing.com/parts/cvs-5323r
Jebby
Old Dec 23, 2020 | 02:00 AM
Corbis's Avatar
Corbis
Jebby, Thanks! I will read up on it, It might be exactly what I'm looking for.
Old Dec 23, 2020 | 10:02 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I went with a Powermaster 9526 on my big block build. It is real nice and has no issues turning things over. The only issue with some of the new starters is they do not have the R terminal on the solenoid.
Old Dec 23, 2020 | 10:24 PM
lionelhutz's Avatar
lionelhutz
Find one from a mid 90's 350 pickup for the 168 tooth ring gear or from a mid 90's LT1 for a 153 tooth ring gear.
To Starter options, '69 350
