Fuel Tank Interchange?
Old Dec 21, 2020 | 12:57 PM
ChrisLSx's Avatar
ChrisLSx
Default Fuel Tank Interchange?
Will fuel tanks from any year C3 physically "fit" in any other year C3?
I've got a 79 and I'm all set on my EFI swap for now (I'm using an 82 EFI sending unit with a Walbro pump), but down the road I would like to swap to an aluminum fuel tank that has baffles so I'd like to know what I can/cannot do.
Old Dec 21, 2020 | 03:02 PM
MelWff's Avatar
MelWff
You already have the largest C3 tank at 25 gallons
https://www.gastanks.com/mobile/1978...ctinfo/GM-72A/
Old Dec 21, 2020 | 03:26 PM
ChrisLSx's Avatar
ChrisLSx
Thanks, but that wasn't my question. As I said, eventually I want an aluminum tank that's baffled and I was curious if different years swap (thus, more options on source).
Old Dec 21, 2020 | 06:14 PM
taylorteamracing's Avatar
taylorteamracing
yes i am fuel inj also, and my car is a 80 what all tanks would go in there would be good to know
Old Dec 21, 2020 | 07:04 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
The later c3 when they went with the big back glass have a different filler neck location from earlier c3. That would cause a big issue in fitting different tanks in your car.
Old Dec 21, 2020 | 07:23 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
68s wont work for you, the sender goes in from the bottom
Old Dec 21, 2020 | 07:31 PM
MelWff's Avatar
MelWff
Only tanks with top sender unit are 75 and newer but an aftermarket aluminum tank application would be determined by the tank manufacturer.
Old Dec 21, 2020 | 08:28 PM
carriljc's Avatar
carriljc
You're complicating the crap out of this unnecessarily. Just get a CANISTER-type EFI pump and return the fuel to the canister. You can adapt the assembly to your 82 sending unit assembly a lot easier than going through the rigamarole of installing a baffled tank.
Here are some pictures of my 68 with a 90s Ford Bronco Canister Type EFI pump. It would have been a lot easier to use an 82 sending unit than to fabricate my own contraption. Never loses suction ... I ran it down to fumes as part of testing...had a friend of mine with me to add gasoline.
Somthing to consider. Lotsa different canister type EFI pumps available nowadays.
https://www.corvetteforum.com/g/album/6185062
And..if you don't want to do something like that then just get one of those Holley Hydramats (expensive, but a lot simpler than a new tank). https://www.holley.com/products/fuel_systems/hydramat/
To Fuel Tank Interchange?
