help again, please!
Old Dec 7, 2002 | 07:14 PM
vettedreams's Avatar
vettedreams
Default help again, please!
Just stopped in out of the shop for a min. The problem is vibration, when the car sit"s at a stoplight in neutral the whole car shakes, the steering wheel shake violently, it"s bad, at about 3500rpm it"s real bad. I believe it"s associated with the engine like I said it happens with the trans in neutral, nothing rotating but the engine. Any suggestions? thanks, now back to stereo installation.
Old Dec 7, 2002 | 07:33 PM
jerryp58's Avatar
jerryp58
Default Re: help again, please! (vettedreams)
Is it just idling poorly? Have you tuned it up recently?
It could be a bad motor mount.
Old Dec 7, 2002 | 07:39 PM
ED DINAPOLI's Avatar
ED DINAPOLI
Check your engine mounts.
Ed
Old Dec 7, 2002 | 07:43 PM
vettedreams
Default Re: help again, please! (jerryp58)
With the lumpy cam she sounds pretty good, I did change the plugs, the wires are fairly new, the carb is rebuilt, and not much for vacuum problems, not a whole lot in that dept. Someone earlier did mention the motor mount , as far as the mounts go, is that something you can see with the engine in the car?, thanks again
Old Dec 7, 2002 | 07:56 PM
redwingvette's Avatar
redwingvette
put a jack under the motor and if a mount is bad it will lift up off of the frame
To help again, please!
