C3 window regulator spring tension rebuild
I sand blasted the whole thing once I got it apart. I used a trim tool to pop the old rollers off and left the shafts in place. I seen in another post how the replacement rollers shafts are longer then the originals. So I will get a couple 3 packs of gm rollers from O’reillys auto store pop the rollers off then put them on the orig. shafts. I have tested this on the bench seems to work. When I was done I just shot grey primer on it. Let me know if this is right or if it helps. P.s. I didn’t have the money to buy 2 new regulators.
On pic 4 I removed the square rivet that holds the arms. It was very sloppy so I was able to dolly the joint and then tig weld the end.
With it clamped in vice I pushed the long arm clockwise to this position. Then put spring on (note center of spring bend start down towards motor)
With sprin on I rotated counter clock wise to catch spring tab. (Note Saftey bolt hole) you’ll need it.
Ok here’s the million dollar question. I kept rotating ccw until the Saftey bolt hole lines up with gear. Install a bolt. Now with that said I rotated about 1/2 to 3/4 turn ccw. With a hand on the arm and no bolt there is unwind pressure trying to take arm clockwise. I just don’t think I could get a full turn on the spring. Note how tight it is in pic.
This opposite side. I replaced the gear and the rivet and the spring rivet in center and for tab. The tab rivet and the just rivet were easy enough to remove and reinstall and just mashed down with hammer. Now the center rivet that holds the spring ( never gots great answer on setting it) so I happen to have a tig machine so I tig welded it. I don’t know if heating it to cherry red and attempting to mash/buck it is doable?
Good job and good photos!
sorry i just seen this , i was talking about the rivet that is in the center that the spring starts on. mine was shaped like an hour glass when i pulled it out. thats when i decided to replace with the new one and tig welded it in. i had to fill the corners cause the new rivet had touch play. i could not find a replacement rivet for the (scissors)arm so i just heated it up and tried to pound it flatter. Hope it helps . Let me know
