Anybody try these LS swap headers?
As part of my pending '75 LS1/4L60E swap I am considering this exhaust from Corvette Central: https://www.corvettecentral.com/c3-6...version-323122
Part of the kit are these headers: https://www.corvettecentral.com/c5-9...etallic-325007
Does anybody have any experience with them? My swap will be very vanilla, basically a stock 2002 Z28 LS1 and 4L60E transmission, I plan on doing the Borgeson conversion as well.
I just finished a LS3 swap into a '73 but I had the body off for that, which made welding up a pipe from the manifold to the center crossmember pretty easy, do not want to try that with the body on and this looks like a good option if there are no snafus along the way.
Scott
My guess is that those headers have the exact same geometry at the exit as the 97-99 C5 headers, does anybody know if that the case? And is the geometry of the 2001-04 Z06 the same as well, once again just concerned about the exit, all of the air port will be blocked off on either manifold.
Scott
https://www.holley.com/products/exha.../parts/2312HKR
Scott
