Chevrolet performance 427 zl1 block?
https://www.chevrolet.com/performanc...aluminum-block
its part number 12370850
Popular Reply
Get a Brodix, Dart, or Donovan and spend the same money for a real block to make real power.
Jebby
Jebby
Jebby
If you're spending your time just going in straight lines, buy the aftermarket pieces. If there's a corner on your track, my preference is the Chevy.
Your money, your choice.
Ahhh... but thats a MASSIVE can ov worms to open up. Massive cubes (read: torque) can cause more problems than it cures when trying to out-corner and brake other cars... especially in a car as light as his. Jack his car 100 cubes and he'll need to jack just about everything else to keep the balance... 427 is still a big engine. I'd take the lighter block too.... IF... its solid. I just slogged through a goddamn 18-page treatise on Speedtalk about the perils ov aluminum blocks. I'm still gonna use one, but man... i'm gonna do my homework.
https://dartheads.com/big-m-aluminum-blocks/
I just got one of the iron versions and it is real nice. Way better than the GM block it’s replacing.
There's a wide variety of cars on the course during track days, and few things look sillier than rocketing down the straights, only to be passed in the braking zone or in the corners. On a road course you'll typically spend two thirds of your time in the corners or the braking zones, and horsepower does nothing for you there. A lighter car comes out of the corners faster than a heavier car, offsetting some of the horsepower "deficit", and doesn't have to slow down as much as a heavier car when coming into the corners. Lighter cars don't need as big (and heavy) of brakes as a heavier car does, and a modest size/hp engine doesn't need as much fuel capacity (ie: weight) to last the duration of each track session. As a couple sayings go, weight begets weight, and weight is the enemy.
As I mentioned earlier, if you're going in a straight line, big cubes and big horsepower will overcome the inertia of a heavy car. But if there's corners in the mix, that big heavy/heavier engine won't be earning its keep a good share of the time.
I don't remember the source (Chevrolet?), but I recall reading that Schwartz was similarly involved in the machining of the original ZL1 blocks way back when.
edit: Ran into an old picture of my block.
My ZL1 block was perfect out of the crate. My builder was really shocked that he had to do absolutely nothing to it. Schwartz Machine did indeed make them and they are a work of art in my opinion.
True enough it was limited in cubes but after you get up past 600hp/torque you are going to have to re-think the rear end of a C3 as was mentioned earlier. How much power does a 50 year old car really need?
Plus you are shaving 200 lbs off the front end. Fully built the engine weighed about the same as a small block.
It was an easy decision to make, especially if you are building a ZL1 Corvette or Camaro 'Tribute'. Its as close as you can get in that world, short of finding & using a really expensive vintage ZL1 block. Therefore the GM label is more valued than all the cubes a Dart can supply.
I can't disagree that a Dart could be built a little cheaper and made more powerful. But it depends on your overall goal and the vision of what you want to accomplish. Looks like the Dart has a raised camshaft location although the stock deck height would work in a 'vette.
It helps to already have a non-ac '69 427 big block car in your garage before you start.
