Engine Cutting out after fuel pump installation
Old Jan 15, 2021 | 12:17 PM
REELAV8R's Avatar
REELAV8R
This is a telling statement..
but had to put it in neutral and keep the revs up to prevent it from cutting out at lights.
Old Jan 15, 2021 | 12:19 PM
REELAV8R's Avatar
REELAV8R
Originally Posted by 7T1vette
We still don't know if the OP installed a 'kinked' straight hose in place of the molded hose. If so, that's the OP's problem. If not....we need to hear more.
I think we do, post #6
Yes used the hoses there as I didn't see any leaks/cracks from them
Old Jan 15, 2021 | 04:13 PM
HeadsU.P.'s Avatar
HeadsU.P.
A fuel starvation situation is harder to acknowledge than a flooding issue. Usually the carb is soaked, sometimes the Intake is wet, black soot out the back.
But your nose will be the first thing to pick up on flooding.
Old Jan 17, 2021 | 10:59 AM
REELAV8R's Avatar
REELAV8R
Disagree.
Very easy to determine the difference. If you go out and accelerate aggressively does the engine cut out during that acceleration (not initial accelerator actuation that is a different issue) or does it continue to run.
If it dies or cuts in and out it's fuel starvation.
If it runs and continues to run, it may burble a lot if really rich, but once you try to idle it cuts out then it's flooding.
