Does anyone know the correct rocker arms used for a 1968 L89 Head. Is it L, M, or H?
I've tried to research it and have come up with conflicting info as the H was said to be used in 69 and 70, M
was used from 65-76 and L from 65-70 i believe?
Also, are these all long slot? I'm using a ls6 cam with an additional .040 lift.
One additional question. What is the correct retainer for this 1968 setup?
