LED headlight upgrade
Decided to do the LED headlight upgrade since I don't have any other major projects. I watched a video of a guy with a C3 and he used Dapper Lighting which he said he had good luck with so I went with them. They aren't cheap but they are very nice. They have the '575' line for 5 3/4" replacement lights. It is a complete unit that fits right into the socket with no cutting. The only issue I had was the tabs on the back which fit into the depressions/slots in the socket did not line up quite right so I just clipped them off. The bezel ring holds them in securely and I was able to keep at least on tab.
Pictures:
Original bulbs on the left (passenger side) the new LEDs on the right.
I haven't adjusted them yet and have not driven it since the car is up on blocks and it's winter haha. Looking forward to that!
Pictures:
The following 4 users liked this post by jim-81:
Looking fwd to reading your first night out review. Which led’s did you go with as they offer both low and high in either 17w or 30w?
gdh (02-24-2024)
Are you taking them somewhere to be aimed correctly or are you doing the wall trick? After I installed headlamp relays I did the wall method then I took it to a shop I know who has the aiming machine. I was off a little but but was pleased I got it as close as I did. Check you local/state laws. Some require machine aiming.
