Split lock washer grade - caliper mounting bolts
Old Feb 21, 2021 | 06:21 PM
jcnst1's Avatar
jcnst1
Default Split lock washer grade - caliper mounting bolts
Stupid question I'm sure, but every time I apply the 70 ft lb torque to the bolt to re-mount my caliper to the bracket, the split lock washer gives way. What grade / type split lock washer is supposed to be used so this doesn't happen.
Old Feb 21, 2021 | 06:54 PM
interpon's Avatar
interpon
I would use grade 8..ace hardware
Old Feb 21, 2021 | 07:20 PM
Gearhead74's Avatar
Gearhead74
I found this question interesting. If you look at information posted by Portland Bolt and Manufacturing Company, you can find this quote:
Generic split Lock washers are not regarded as structural components, since they are just fixing a nut into place, and thus do not have the same amount of scrutiny that nuts and bolts have. Due to this, there is currently no ASTM specification that covers a generic split lock washer. Also, there is no high strength lock washer specification by ASTM and generic lock washers are often used with high strength bolts, since there is no “high strength” lock washer specification or any grades at all for that matter.
Since there are vendors selling split lock washers as grade 8 and possible other grades, I looked to see what others were using for brake calipers. While I've never used them, it seems many are using Nord-Lock washers. I'm curious if other forum members use these Nord-Lock washers and if so, use the old style of the newer X-Series.
Old Feb 21, 2021 | 08:01 PM
Mooser's Avatar
Mooser
There's generally 2 types available, good (usually called hardened, through hardened or gr8) and the the ones that you get and the "general" hardware stores that distort, open and really don't do much (possibly made from cheese but I'm not 100% sure)
M
Old Feb 21, 2021 | 08:32 PM
jcnst1's Avatar
jcnst1
M
Yes, my original attempt was from HD, and they split with little torque.....frustrating. Found Grade 8 at Lowes, and they withstood the torque. Anyway, just don't want my caliper coming loose at some point
Old Feb 22, 2021 | 07:38 AM
69L88's Avatar
69L88
The only stupid question is one that doesn’t get asked and leads to a bubba “fix”.
McMaster-Carr and Fastenal are excellent sources for specialized hardware.
Old Feb 22, 2021 | 07:56 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Put a little Moly on the washer.....and the shoulder of the bolt.
Jebby
Old Feb 22, 2021 | 09:39 AM
lionelhutz's Avatar
lionelhutz
You need really, really good split washers for them to have any chance of being useful.
Belleville (spring) washers or Nord-Lock (wedge lock washers are better solutions if you really want the washer to retain the bolt. The spring force of the belleville washer needs to be properly matched to the bolt tension when torqued.
A tab lock washer that you bend one tab over the side of the caliper and another tab against a bolt flat would also work very well to keep the bolt from coming loose.
Old Feb 23, 2021 | 09:54 AM
L88Plus's Avatar
L88Plus
^ what he said. You'd have too have such a high grade spring steel for traditional split lock washers to be able to actually produce any preload that it's almost impossible.
Old Mar 1, 2021 | 09:53 PM
jcnst1's Avatar
jcnst1
Thanks for all the replies. I originally got stainless steel at Home Depot....they were worthless. Then went to ACE Hardware - who have a much better selection for specialty hardware items - and got Grade 8 Stainless Steel. They held up perfect, so glad I went the extra step.
To Split lock washer grade - caliper mounting bolts
