Mechanical Roller Cam - Engine Vacuum Question
Old Feb 24, 2021 | 09:29 AM
JC 1975's Avatar
JC 1975
Default Mechanical Roller Cam - Engine Vacuum Question
I’m looking to purchase a matched cam kit (cam, lifters, springs, etc..) for my engine, but want to make sure I have enough engine vacuum to run all the vacuum accessories. From what I’ve read, I need to stay under 240 @ 50 to ensure adequate vacuum. Is this an accurate statement? I know lobe separation also plays a factor due to valve overlap. I have found two mechanical/solid roller cams that look good, but with 11:1 compression of my LT1 short block, are these cams too mild? Looking at compression vs duration charts, it states I need to be at 240 degrees at 50 with 11:1 compression.
Thanks in advance!
https://www.lunatipower.com/voodoo-s...k-261-267.html
https://www.compcams.com/xtreme-ener...all-block.html
Oh, trans is a TH350 with 2200/2500 stall converter, 3:55 gears, the cars weights roughly 3,300lbs.
Old Feb 24, 2021 | 09:33 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
What heads are you running?
Is this a 350 still?
I built my Dad a 350 in 1999 with a 244@.050 cam in it and it pulled 11 inches of vacuum......the roller will pull more as you can't compare flat tappet duration to roller duration.....different worlds.
Jebby
Old Feb 24, 2021 | 09:50 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Those cam specs @0.050" are very similar to my Howard's hydraulic roller with a 112 lsa. I have 14-15" vacuum at 850 rpm.
Old Feb 24, 2021 | 10:05 AM
JC 1975's Avatar
JC 1975
Jebby
They are Phase 2 Bowties- which will receive some porting. Unfortunately the information out on the web is very generic, which is why I come here to get better info!
Old Feb 24, 2021 | 10:07 AM
JC 1975's Avatar
JC 1975
From what I’ve read the 112 LSA will give you better vacuum than 110. But all of these cams I’ve found are on a 110 unfortunately.
Old Feb 24, 2021 | 10:49 AM
eff10mm's Avatar
eff10mm
I had no issues with vacuum. I ran the mildest solid roller from Comp Cams. I bought a complete kit from them with cam, lifters, springs, pushrods and timing set. I loved the sound and the way it revved, but after 3000 miles a roller lifter dumped it's needle bearings and destroyed my engine. I had bought the street lifter that were supposed to be long life. When I called Comp about the failure they just told me "sounds about right" for 3000 miles. I would stay away from CC entirely. They like to rush products to market and let the public be the beta testers. I went back to hydraulic rollers and I don't miss the valvetrain maintenance.
Old Feb 24, 2021 | 10:59 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Yes, but did they say how much more? I think you'll still have enough vacuum to operate the accessories at 110.
Old Feb 24, 2021 | 11:07 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Chamber size?
Jebby
Old Feb 24, 2021 | 11:36 AM
JC 1975's Avatar
JC 1975
Yah, I’ve read articles regarding that issue. It appears its from low rpms and the lifters not getting enough oil splash from the crankshaft. To be honest, it will take me 20 years to drive 3,000 miles. It rarely gets driven. The cylinder walls still have their cross hatching and the engine is old!!!
JC 1975's Avatar
JC 1975
Chamber size?
Jebby
They’re 64cc’s
Old Feb 24, 2021 | 11:38 AM
JC 1975's Avatar
JC 1975
I think Jebbysan is correct with around 11, give or take a few.
Old Feb 24, 2021 | 12:28 PM
REELAV8R's Avatar
REELAV8R
As I recall for a solid lifter cam you can subtract 10* from the duration to compare it to a hydraulic lifter cam.
given that the larger cam you spec’d would be better, but I believe you could go with more duration if it’s a 383 even if a 350 depending on what you want performance wise.
be sure to check your DCR with an 11:1 CR. You may need more duration to avoid detonation.
DCR with iron heads max 8.5:1
aluminum 9.0:1
Old Feb 25, 2021 | 04:01 PM
C3 Stroker's Avatar
C3 Stroker
I've had enough vacuum with a cam on a 108° LSA, 250/254° @.050 duration (11° vacuum)......all accessories worked fine. My current cam is on 112° LSA, with 259/265° @.050 duration and I have 12° vacuum with everything working fine. So it kinda depends on the grind and the total engine specs. If you see one you like at 110 LSA, but prefer it at 112, just have it custom ground......Comp Cams does this at no extra charge.
To Mechanical Roller Cam - Engine Vacuum Question
