LS Swap - Neutral Safety Switch input source
Old Feb 27, 2021 | 02:48 PM
ScottEwine's Avatar
ScottEwine
Default LS Swap - Neutral Safety Switch input source
Good Afternoon All,
I am working on the harness for the 2002 LS1 / 4L60E I am putting in my '75. I have everything done except the neutral safety switch signal to the ECM. I know this should be grounded in neutral and park, and otherwise open, and I know how to wire up a relay to get that signal correctly from a good source, my question is what is that source? I have the new correct switch on my shifter from shiftworks and my first thought was that I can get the 12 volts from the downstream side of the switch, but it seems that the only time that 12 volts passes through the switch is when the ignition is in start, otherwise there is no voltage on either side of this switch, correct? Meaning that the ignition switch is upstream in the circuit. If this is the case how are people getting the correct signal to the ECM in park and neutral?
Thanks,
Scott
Old Feb 27, 2021 | 05:31 PM
71 Vert LS1's Avatar
71 Vert LS1
On my C3 LS swap I used the Shift Works detent conversion and used the stock C3 shifter neutral safety switch. The ECM typically doesn't need a signal from the neutral safety switch. As I recall on my 71 C3 there was a purple? wire coming from the under dash wiring to the switch and the other purple wire going out to the starter.
I used a meter to check the neutral safety switch adjustment before I got the car running.. Should be open in park and neutral. And then before I put the console on and had the car running I carefully checked the park and neutral positions with the rear wheels off the ground.
On my LS swaps I have not used the "stock" 4L60E neutral safety switch on the side of the trans. but if you do per the LS1tech guys that switch will not handle the amps and it needs to feed the starter thru a relay.
Old Feb 27, 2021 | 09:16 PM
ScottEwine's Avatar
ScottEwine
I see that many say the ECM does not need that signal, since it was clearly marked on the harness I had reworked I thought maybe it was as important as the brake signal, for example. I got a new shiftworks neutral safety switch along with the detent conversion and plan on testing and adjusting it similarly it out once I get it all installed.
Old Feb 27, 2021 | 09:47 PM
71 Vert LS1
Having said above you do need a brake light switch with two sets of contacts. One set for the brake lights and one set for the torque converter lock/unlock. The one I'm using on my 1980 Camaro LS swap is NAPA part number SL186. I've also used a 2002 Camaro auto brake light switch. In regards to C3's I wonder if the 1980-1982 brake light switch has two sets of contacts? If it does it might bolt right in so to speak.
Old Feb 28, 2021 | 07:24 AM
ScottEwine's Avatar
ScottEwine
I have a relay wired into my new LS fuse block for this already, planning on doing the same thing I did on my 73, splice into the brake light signal on the pedal and reverse the signal with a relay based on Brendan's diagram below.
Scott
Old Feb 28, 2021 | 09:37 AM
'75's Avatar
'75
Here's what I did to my 80 TPI conversion. Look in the upper left corner of the diagram.
Old Feb 28, 2021 | 10:20 AM
Factoid's Avatar
Factoid
To your original question on the neutral safety switch, ground one side of the switch and run the other side to the ecm. Don’t make it more complicated than necessary.
Old Mar 1, 2021 | 08:00 AM
ScottEwine's Avatar
ScottEwine
I think this would be a good fix if I was not continuing to use it for the original purpose, I still have it wired into the purple/purple-white wires in the harness.
Scott
Old Mar 2, 2021 | 01:23 PM
lionelhutz's Avatar
lionelhutz
It'll work fine without it. I've run cars without the brake pedal switch for lots of miles too and have yet to have anything odd or bad happen. The TCC still works just like any other vehicle with the switch.
To LS Swap - Neutral Safety Switch input source
