Hydraulic lifters are... noisy ?
Old Mar 2, 2021 | 03:10 PM
DorianC3's Avatar
DorianC3
Default Hydraulic lifters are... noisy ?
Dunno. What do you think ? Does this sound normal ?
This is after one minute of running and real close to rockers. It’s less audible at a distance.
I don’t know if you hear this the way I do, but to me this doesn’t sound right. No amount of adjusting preload, static or dynamic, seems to make a difference.
The cam is supposed to have a noticeable lope. But I don’t think I like the idle.
I’m also getting a rapid vibration of my vacuum gauge needle. Slow motion shows it to be very regular.
Ignition is good.
carb is EFI
I just came from a more aggressive cam... well sorta. The vacuum was a stable 14.5 inches. I should be getting around 19 inches.
Compression test is around 200 PSI on all cylinders. Leak down is very good as well.
What happened ?
I installed a Comp Cams Extreme Energy Retrofit hydraulic roller cam and Comp Cams Hi-Energy hydraulic roller lifter.
Any thoughts ?
Could these be the incompatible springs ?
No binding of pushrods or geometry, etc.
Old Mar 2, 2021 | 03:19 PM
augiedoggy's Avatar
augiedoggy
I have yet to fire up my comp retro roller cam setup but I have read that the link bar style retro lifters are noisy.
Old Mar 2, 2021 | 03:26 PM
DorianC3's Avatar
DorianC3
These are link bar style, yes. I’ve had a link bar retro on another car. (Dunno if it was complete cams.) I don’t think they were noisy.
Old Mar 2, 2021 | 04:11 PM
DorianC3's Avatar
DorianC3
It’s also possible this is entirely normal valve train noise for my set up and I’m just expecting too much as compared to my low performance boat anchor.
Old Mar 2, 2021 | 04:16 PM
MelWff's Avatar
MelWff
Exactly what procedure did you do to adjust the valves?
Old Mar 2, 2021 | 04:21 PM
DorianC3's Avatar
DorianC3
Exhaust Open Intake Close method. Zero plus 1/2 a turn.
Old Mar 2, 2021 | 04:35 PM
MelWff's Avatar
MelWff
The instructions that came with the cam didn't state 1 full turn past zero lash?
Old Mar 2, 2021 | 04:52 PM
DorianC3's Avatar
DorianC3
Not on these. I even called Comp Cams to verify.
Old Mar 2, 2021 | 05:27 PM
jeffwebley's Avatar
jeffwebley
I have full roller rockers, and they make a clicking sound from the clearance between the rocker stud and the ID of the rocker pivot.
With the engine off, see if you can move the whole rocker ***'y from side to side. If you can, that's a likely explanation.
Good luck.
Jeff
Old Mar 2, 2021 | 05:48 PM
DorianC3's Avatar
DorianC3
Good luck.
Jeff
Ah-HA !!!! Now that’s interesting. Indeed, I noticed that. I can. I can move them from side to side the amount of clearance that the guide plates allow.
Ha !!! Could it be that simple ???
Hmmm. That does make sense. That would also explain why putting the tip of a stethoscope to any of rocker studs reveals a distinct clacking sound for each. If it had been a lifter... not all of them would be making that noise. In this case, pretty much all the studs sound the same.
Old Mar 2, 2021 | 06:33 PM
jeffwebley's Avatar
jeffwebley
Cool.
From your description, it sounds like mine, and I hear the same sound in your video.
Hope this is the solution.
Jeff
Old Mar 2, 2021 | 06:39 PM
DorianC3's Avatar
DorianC3
Quite sure that it is. Thanks !!!!
Old Mar 2, 2021 | 07:15 PM
twinpack's Avatar
twinpack
Mine sounds the same.
Old Mar 2, 2021 | 07:41 PM
HeadsU.P.'s Avatar
HeadsU.P.
That sounds terrible even without my hearing-aid. I would not want that nor would I leave it like that. That is the sound of parts breaking in the future.
How was the pushrod length verified with this new setup? Are you confident about the valvetrain geometry?
Are the pushrods a different diameter than what the guide plates allow? (excessive play)
On the rocker pivot shaft. Is it possible that they can be installed up-side-down? In other words, both sides of the pivot look exactly alike and not one side round, the other side flat?
Old Mar 3, 2021 | 10:07 AM
7t9l82's Avatar
7t9l82
Pushrod length could be a factor I'd check that.
Old Mar 3, 2021 | 10:50 AM
DorianC3's Avatar
DorianC3
The rocker pivot shafts are indeed recessed for the poly locks, but I caught that and they are all installed the right side up.
I did verify the geometry. It’s spot on.
The rockers are made so that they will “top out” on the poly locks before they bottom out on the stud.
There is some play between the guide plates and pushrods. But I think it’s within spec. What clearance should there be ?
Old Mar 3, 2021 | 11:56 AM
OMF's Avatar
OMF
Your problem is the Extreme energy cam....the ramp rates on those cams are....well.....extreme. Mine sounded like a solid cam most of the time (just like yours does in the vid) and no amount of adjusting could get rid of it. I now have a slightly larger cam from Crower, no valvetrain noise at all. The only change made was the camshaft...., same lifters, pushrods, rockers and locks. I tell folks all the time to avoid this series of cams if they want a quiet valvetrain.
Do a search on the Extreme Energy series of cams, you'll get echo's of what I just said.
To Hydraulic lifters are... noisy ?
Old Mar 3, 2021 | 01:23 PM
DorianC3's Avatar
DorianC3
To quote Spock: fascinating !
And that makes a lot of sense. The lifters are “Ho -Energy” but I was always intrigued by the “Xtreme Energy” cam. Were the really compatible? I did read something somewhere about the ramps.
I’ll do some research... but that makes a lot of sense.
It’s not the lifters. It’s the cam.
Old Mar 3, 2021 | 02:01 PM
DorianC3's Avatar
DorianC3
Thank you @sstocker31 I read a bunch of articles on the topic. This is exactly what I’m experiencing.
It does make me I have a solid cam under the hood. Fortunately I don’t drive around with my head under the hood and I can barely hear it from the driver’s seat.
i can get used to it (for a few years at least) as long as I know it’s normal.
Thanks !
Old Mar 3, 2021 | 04:01 PM
HeadsU.P.'s Avatar
HeadsU.P.
I disagree. I have had an Extreme Energy cam for several yrs now with over 500 lift. Not a peep comes from my valvetrain. And mine is a Flat Tappet.
Your Roller should be even quieter than a peep.
Its not the cam. Its something else. The fast ramps you mentioned is valve opening action rate. Not closing rate. Noises come from the valves closing.
You say the rockers top-out before they bottom out on the stud. I suspect that they are not. When you think your valvelash is set, I think they are not. You have too much play. You stated the rockers move side-to-side easily. Can the pushrod be spun easily on a closed valve of course?
