Thanks for taking the time to respond, Iam having some electrical gremlins that are getting the best of me. Besides courtesy lights having no power at fuse block, now I noticed that only the drivers side brake light works, I have checked the simple stuff, fuse is good, bulb is good, turn signal works, lights work when turned on, just no power when brakes are applied just to the pass side.
According to wire diagrams the brake wire appears to be the dark green, any ideas on where to chase this side of the circuit down to? This is over my head and would appreciate any ideas. Makes me scratch my head that all other tasks work in the socket just not the brakes.
If turn signal and lights are working on the pass side, the ground seems to be OK (often a problem).
Since the lights are "daisy chained" did you check the connection between driver's and pass side lights?
Try connecting a Temporary single ground wire to the bulb socket that is not lighting up. Also use a voltage meter to read 12 volts positive on the brass contacts inside the bulb Socket. Are the light bulb socket brass contacts clean and shinny (making a good electrical connection)? Try these tests before attempting to remove/disconnect wiring harness? Use a good light to inspect the wiring harness from under the car, look for taped areas or cuts, routinely found in work done by Bubba or his Cousins. Let us know what you find.
Have you tried jiggling the turn signal lever (in the off position) while stepping on the brake peddle?
(the brake light circuit go through the turn signal switch and sometimes those contacts get dirty / loose)
Well my friends, as has been said its usually the simple stuff. After testing as suggested it was a bad socket, weird how they can be so finicky. I really thought I had a bad bubba wiring hob on my hands. After putting in new socket everything works fine now. Thanks for all the help.
Now I need help on why the interior lights stopped working. I have no power at the fuse at all, either side. They worked when I first started working on car now don't. Fuse is good.
