Carb issues LT1 1971
Old Mar 18, 2021 | 11:25 AM
Jas01's Avatar
Jas01
2nd Gear
Default Carb issues LT1 1971
Hi, new member here!
I have a 71 LT1, and it runs great as long as you have like 2000revs and up. But when i´m getting rolling from start it will choke it selfs and somtime it misfires throu the carb.
I went out to the garage and noticed that i most likley have a carb from a 1970, could this be the problem or is it just tuning that i need?
Sorry for the broken english, i´, a swede :-)
Old Mar 18, 2021 | 11:53 AM
sw69vette's Avatar
sw69vette
It should run good with a 1970 carb . How did it run in the past ??? Check to make sure choke is fully opened , check timing , make sure firing order is correct , cap and rotor OK ( no cracks )
plug wires OK
Old Mar 18, 2021 | 12:23 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Look down the choke horn and look at the squirter......whack the throttle a couple times.....is two nice streams squirting into the bores? If not.....you need an accelerator pump. Remove the front bowl and it is on the bottom. Google it up if you are not sure.......the pump diaphragm is very cheap and easy to change....be prepared to need a new float bowl gasket.
Jebby
Old Mar 18, 2021 | 01:18 PM
Sayfoo's Avatar
Sayfoo
plug wires OK
All this /\
Also, a can of SeaFoam, etc. can sometimes preform miracles with a carb that has got a little gummed up.
Old Mar 18, 2021 | 02:14 PM
Dirty Dalton's Avatar
Dirty Dalton
I have a 71 LT1, ...
We need pictures! Welcome to the LT-1 club!
Old Mar 18, 2021 | 03:03 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
When was the last time you checked your timing? Too far advanced and it can back fire through the carb. Check your timing first before adjusting your carb.
Old Mar 25, 2021 | 03:18 PM
firstgenaddict's Avatar
firstgenaddict
Rarely are the carbs set up correctly on a LT1.
Often the divorced choke is not correct - correct full choke has an idle of 2400 RPMs.
A long aluminum runner in the intake will cause fuel to fall out of solution and lean the mixture thus it needs more velocity until warm.
Old Apr 1, 2021 | 04:54 AM
Jas01's Avatar
Jas01
2nd Gear
Thank you all för good tips. I have done general adjustments on the carburator, and that works, no more misfire thru the carburator. It starts easy and idle quite high but as far I understand on all cylinders.But when I start to drive it starts weak and it obvisly don´t work on all cylinders. Next step for me is to use a vacuum meter och do some fintuning along with setting the timing. When the motor is warm it works fine except at low rpm. I hope i can fix it as sonn as possible, spring is comming!
Old Apr 1, 2021 | 08:39 AM
Dirty Dalton
"but when I start to drive". Do you mean after just starting with engine still cold? Mine is often akin to a bucking bronco after a cold start.
Old Apr 1, 2021 | 08:53 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Lots of good info above. You could have a vacuum leak or your vacuum advance could be seized. During low RPM the carbs are operatig om the idle circuit until the transition over to the primary circuit. I would check your idle set screws and check the power valve and the accelerator pump. Your carb may need a general rebuild if its new to you, or just a good tuning. I would check your timing as was suggested.
Old Apr 1, 2021 | 09:24 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I always had an issue with the choke on my 70 LT-1 for 27 years. Depending on how I adjusted it it would:
1) start quickly, but then buck a little when the choke was still on, until warm, so it was difficult to drive until it completely warmed up, (or)
2) With a slightly different adjustment, it was guesswork to start ( two pumps or three?) and it usually quickly stalled requiring multiple starts. But then once started it ran terrific with a partial choke, for 2-3 minutes, and was actually driveable, until it warmed completely up.
I never found one adjustment that got it to do both issues well.
Old Apr 2, 2021 | 09:19 AM
firstgenaddict
#1 is the way it should be set up, they were not designed to get in and go COLD, like you said, once it's at OPERATING temp it was fine.
I try to give mine 5 if not 10 minutes to warm up - at least down off the high idle to 1500 or so prior to taking off - it is much easier to drive -
* I have found if it is down right cold outside I almost have to warm it up before going anywhere or as soon as you give throttle it snorts and pops.
To Carb issues LT1 1971
