Body Lifting?
Old Dec 12, 2002 | 12:51 AM
WashingtonRacer's Avatar
WashingtonRacer
Default Body Lifting?
How would you lift the body enough to replace the mounts? what is the easiest way to go about doing this?
Old Dec 12, 2002 | 01:26 AM
paintdaddy's Avatar
paintdaddy
Default Re: Body Lifting? (WashingtonRacer)
Ive never done this but it seems like you could unbolt all of the mounts and use a 2x4 to jack the body up just enough to slide the new mounts in.
Old Dec 12, 2002 | 02:42 AM
WashingtonRacer
Default Re: Body Lifting? (paintdaddy)
thats an idea, Seems possible, Now how about front end adjustment. Does the body move much between the front end "firewall forward" and the back end? I have that "what looks to be common wheel well alignment issue where one tire sticks out more than the other.
Old Dec 12, 2002 | 03:38 AM
paintdaddy's Avatar
paintdaddy
That doesnt sound good!Is this a common problem.Ive never heard of it.Are you saying that the wheels are straight from top to bottom ,just one sticks out and the opposite side is pushed in? :confused:
To Body Lifting?
