The cam in this kit is comparable to an L-82 camshaft....224/224@.050 .465/.465 on a 114......it is a mild performance grind and does everything right....good idle, good power. The heads are rated for .475 lift....kinda close on the rating, getting close to the max.......but it should work.....it would have to be mocked up if I were doing it before the engine was assembled.
The Jeg's intake flows well, unsure about quality. I would use a Holley 0-90670 Truck Avenger carb on this and a nice set of long tube headers.
I wonder why it comes with pushrods as that is something that needs to be checked.......
The whole list of parts with links is available if you scroll down.
This setup would make somewhere in the neighborhood of 360-370 horsepower on a dyno.....about 300 to the tire. As powerful as an 70-72 LT-1 through headers.......
Actually a nice combo but too many unknowns here and I am not huge on Vortec heads......
I'd like a 1..6 rocker but with the vortec heads would require machining and different pushrods.
I never was a big fan of vortec heads either but I know people like them .
