Contact Breaker Points - 1980
Old Mar 23, 2021 | 03:58 PM
Floydy's Avatar
Floydy
Default Contact Breaker Points - 1980
Hello,
I recently purchased a 1980 (non-CA) that is bone stock. I want to do a tune up and replace all the common parts that wear out after 40 years. I've found some good kits on Zip Corvette and other sites but I can not find anywhere a reference to the contact breaker points for the distributor. I see the cap, rotor etc. but no points or condenser. I'm pretty sure (well I think I'm pretty sure) that this model did not have electronic ignition so I'm confused by the apparent lack of breaker points.
Any insight would be much appreciated!
Old Mar 23, 2021 | 04:08 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
A stock 80 has HEI; HEI does not have points. Cap, coil, and module may need to be replaced.
Old Mar 23, 2021 | 04:25 PM
HeadsU.P.'s Avatar
HeadsU.P.
Since '75.
If the module is original, that would be a smart replacement.
Keep the old one in one of the rear compartments along with tools to replace it.
Old Mar 23, 2021 | 04:28 PM
Floydy's Avatar
Floydy
Thanks for the quick answer - rotor also, right?
Old Mar 23, 2021 | 06:28 PM
MelWff's Avatar
MelWff
Yes rotor also.
Old Mar 23, 2021 | 07:13 PM
HeadsU.P.'s Avatar
HeadsU.P.
Cap & Rotor kit go hand n hand. Usually get a price break with both.
The spare module is like a can of Fix-A-Flat. Just incase. And when they go, its without warning. Just drop-dead, no spark.
I keep a used Modge in a ziplock bag, coated with heat sink compound and the tools needed to change it in a rear compartment.
I have been stranded before because of those GM modges.
A modge is $50.
A towtruck is $70
Old Mar 24, 2021 | 03:44 AM
tfi racing's Avatar
tfi racing
Originally Posted by HeadsU.P.
Since '75.
Original module is likely better than the chinese garbage out there now, I would rather keep a new one as an emergency spare. Pick up coil is the more likely failure on a GM HEI, change it out if the wires seem to be a bit crusty, does require pulling the distributor and disassembling it to change though.
To Contact Breaker Points - 1980
