Coolflex radiator hoses
Old Dec 12, 2002 | 12:48 PM
Teuffelhunde's Avatar
Teuffelhunde
Default Coolflex radiator hoses
Have any of you ever tried these or heard about them? Are they any good? Just read about it in Rod and Custom and they sound really :cool: . Here's a link for anyone who has never heard of them. www.coolflex.com
Old Dec 12, 2002 | 02:08 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Coolflex radiator hoses (Teuffelhunde)
never use a hose that does not have a smooth inside as this will disturb the water flow. been there tried that. :chevy
Old Dec 12, 2002 | 02:16 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: Coolflex radiator hoses (clem zahrobsky)
Those hoses are smooth inside. They are basically a hose with a cool accordian type cover on them. Very cool but very expensive IMO.
Old Dec 12, 2002 | 02:31 PM
pws69's Avatar
pws69
Default Re: Coolflex radiator hoses (tshort)
Actually, I do not believe they are smooth inside - just the rubber END PIECES that splice the copper flexhose to the in/outlets.
Old Dec 12, 2002 | 02:37 PM
mapman's Avatar
mapman
Teuffelhunde,
A while back "silvervetteman" posted the comment below, I have included the link to this discussion. Seems like good advice to me.
Those hoses look :cool: , just be careful of their route. Several members also recommend drilling a hole(s) in the thermostat to help prevent air entrapment in the block. You might want to search the archives on thermostats.
http://forums.corvetteforum.com/zero...638505#4638505
Original Quote: [If you have all of the radiator seals and a good clutch fan you won't have any heating problems. Just make sure that the upper radiator hose isn't routed so ANY portion of it is higher than the pressure cap or it will vent coolant and run warm. (Air goes to the high spot and forces water out). My stock system with R134a is fine even here in Florida. The coolant temp rarely goes above 200 even in traffic and 95 deg weather with A/C . Normal is around 170-180. ]
Old Dec 12, 2002 | 02:45 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
That's what I have.... They look very cool!!!
:cheers:
Olivier
Old Dec 13, 2002 | 06:19 AM
Red73's Avatar
Red73
Default Re: Coolflex radiator hoses (GrandSportC3)
To Coolflex radiator hoses
