More Small Block Chevy trivia
Old Dec 12, 2002 | 02:41 PM
Neo Fender's Avatar
Neo Fender
Default More Small Block Chevy trivia
The first SBC debuted in 1955. It displaced 265 CI. Other than this, what makes the 265 unique from its successors?
First correct answer gets a back rub from the moderator of their choice.
Old Dec 12, 2002 | 03:19 PM
Tom73's Avatar
Tom73
Default Re: More Small Block Chevy trivia (Neo Fender)
could it be the camshaft oiling?????
tom...
Old Dec 12, 2002 | 03:21 PM
Neo Fender's Avatar
Neo Fender
Default Re: More Small Block Chevy trivia (Tom73)
That may be correct but that's not what I have in mind. You're not too far off, though.
Old Dec 12, 2002 | 03:23 PM
honaker's Avatar
honaker
I just read this the other day. I'm sure it has something to do with the oil system.
Old Dec 12, 2002 | 03:25 PM
Neo Fender's Avatar
Neo Fender
Default Re: More Small Block Chevy trivia (honaker)
I'm checking out for the day but I'll be back in the A.M. to see who the lucky winner is.
Old Dec 12, 2002 | 03:31 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I never owned a 55, but I had a 54 and a 57, so I'll make a wild guess based on what I remember about the differences between those two cars. Was it the only Chevy year to have a 6 Volt starting/ignition system with the V8?
Old Dec 12, 2002 | 03:34 PM
john's '81 mouse's Avatar
john's '81 mouse
Not originally equipped with an oil filter???
Old Dec 12, 2002 | 03:42 PM
Smokehouse69
Ok, guess number two for me! Firewall mounted canister oil filter!
Old Dec 12, 2002 | 04:06 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: More Small Block Chevy trivia (Smokehouse69)
first to have an oil PUMP
Old Dec 12, 2002 | 04:18 PM
Larry B.'s Avatar
Larry B.
There are a few differences.. No oil filter, no motor mount bosses on the side of the block, and the oil system is a little different in that the cam MUST have a flat on the rear bearing surface or one bank will not get oil. :sleep:
[Modified by silvervetteman, 4:19 PM 12/12/2002]
Old Dec 13, 2002 | 07:11 AM
Neo Fender's Avatar
Neo Fender
Default Re: More Small Block Chevy trivia (john's '81 mouse)
We have a winner (this was the answer I had in mind).
To More Small Block Chevy trivia
