Vibe Question for the Engineers
Old Mar 29, 2021 | 12:28 PM
Sammy T's Avatar
Sammy T
Default Vibe Question for the Engineers
1. To set the stage: All rotating accessories have been eliminated as a potential problem. Clutch/Flywheel package is balanced as an assembly. New Pilot bearing. New trans mounts and engine mounts. Nothing is hitting the frame. Ignition and fuel eliminated as a source. New OEM style harmonic damper. Base model 350.
2. Problem: Engine vibe around 3200 RPM so that is what, about 213Hz. Can't test the multiple at 6400 RPM because, well, the engine can't do that. Half would be 106 at about 1,600 RPM. I don't really feel the vibes there.
3. Question 1: What is the typical Hz damping range for an OEM style damper on a SBC 350 CID?
4. Question 2: Would an aftermarket damper with a wider frequency range possibly eliminate this issue?
5. Question 3: What are the possible causes of 213Hz vibrations in a SBC?
Thanks!
Sam
Old Mar 29, 2021 | 12:40 PM
Mr D.'s Avatar
Mr D.
What is an example of a 213Hz vibration and how did you measure that?
Old Mar 29, 2021 | 12:43 PM
Sammy T's Avatar
Sammy T
Example? No idea.
Calculated: 3200 RPM x 4 (for a V8...completes one engine revolution)/60Hz = 213Hz
Old Mar 29, 2021 | 01:04 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Was the engines rotating assembly balanced properly when it was built? Do you have bobweight sheet?
Jebby
Old Mar 29, 2021 | 01:09 PM
Sammy T's Avatar
Sammy T
Jebby
Don't know and no. Bought the car log after the engine rebuild. The starting assumption is that it is correct...which may not be the case. But, I have to start somewhere to eliminate all other possibilities because an improperly balanced rotating assembly means I get to rebuild the engine.
Old Mar 29, 2021 | 01:19 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Has it done it the whole time since you have purchased it? If so...then yeah, it is out of balance if you have ruled out all other things.
You could try bolting a high quality balancer (Like Pioneer) on it and see if it changes......but it would be unlikely unless your current unit is dry rotted and/or spun.
EDIT: Re-reading your OP....I see you have a new one on there already.
Jebby
Old Mar 29, 2021 | 01:24 PM
Sammy T's Avatar
Sammy T
Jebby
Ahhh yes...that question. The car ran so poorly from various issues (carb, valves, alignment, vacuum leaks) when I got it, its hard to say. Rebuilt the carb, set the valves, ignition wires, cap, rotor, points, timing. How did it run? The one time I can remember (there may have been other drives but I simply don't recall them) it ran through the rev range smoothly. I even commented to my wife about it. Since then, well, new clutch/flywheel package, heads, balancer, drive shaft, half-shafts, rear trailing arms, alignment, engine mounts, trans mounts, cam, timing chain, exhaust system (stock). Could one of those altered how it runs? Sure.
Old Mar 29, 2021 | 01:27 PM
CAMS69's Avatar
CAMS69
Thanks!
Sam
engine internal balanced vers/ external balance. age old
Old Mar 29, 2021 | 01:30 PM
76strokervette's Avatar
76strokervette
Check all mount bolts and make sure they are tight.( motor ,trans and crossmember)
Old Mar 29, 2021 | 01:31 PM
Sammy T's Avatar
Sammy T
Internally balanced 350.
Old Mar 29, 2021 | 01:33 PM
Sammy T's Avatar
Sammy T
Good thought. They are all torqued to spec.
Old Mar 29, 2021 | 01:40 PM
69L88's Avatar
69L88
Does the vibration manifest with the car standing still?
Old Mar 29, 2021 | 01:42 PM
Sammy T's Avatar
Sammy T
Yes. Independent of vehicle speed, gear, moving, static, clutch in or out.
Old Mar 29, 2021 | 01:54 PM
CAMS69's Avatar
CAMS69
vibes only at 3200 or they start at 3200? vibe is a feeling in your butt? or a sound or?
Old Mar 29, 2021 | 01:56 PM
Sammy T's Avatar
Sammy T
Start at 3200...seem to kinda stay the same until about 4k...less noticeable (or just a higher frequency that I can't feel as well)
No sound...can feel it in the car. So, yes...butt.
Old Mar 29, 2021 | 02:05 PM
OMF's Avatar
OMF
How about a cylinder misfire starting at 3200.....is that a possibility?
Old Mar 29, 2021 | 02:09 PM
Sammy T's Avatar
Sammy T
For a while I thought it was ignition related as well. And it may still be. New plugs, new wires, new cap, new rotor and switched to Breakerless SE ignition. Coil in spec. Still could be misfiring for some reason. Seemed to get a LITTLE better...After all that, not sure how it could STILL be misfiring.
To Vibe Question for the Engineers
Old Mar 29, 2021 | 02:12 PM
CAMS69's Avatar
CAMS69
hmmmm, unless its a really intense vibration, this is seeming normal....
So tell us how intense the vibration feels? Compare it to something we have all experienced, like an electric tooth brush or driving to far to the right over the vibrating road strip ...
Old Mar 29, 2021 | 02:26 PM
Sammy T's Avatar
Sammy T
Its a clear change from normal engine running vibration. Example...tough question...how about a slightly unbalanced drive shaft or a slightly out of balance tire?
I know, this is weird.
Old Mar 29, 2021 | 03:12 PM
CAMS69's Avatar
CAMS69
Im going with harmonic balancer. To test this get a large hunk of metal with a hole or a tab so the metal chunk will be cantilevered out from the engine. find a suitable place to bolt it on the engine and re-rev to over 3200....
suitable bolting locations? head bolt hole for accessories, on and accessory it self, exhaust bolt , in take bolt, etc you get the picture..
