LS 5 timing order
Old Apr 2, 2021 | 10:56 AM
grumman41's Avatar
grumman41
Default LS 5 timing order
I swapped some wires on a new engine a few years ago and now the engine doesn’t start. It’s good engine that ran fine on the dyno. I have the diagram of sequence on the dist and plugs. I brought the compression up on number one and started the plug wires in sequence. Not sure where to go from here. This is a stock LS five ignition system.
Thanks in advance!
Old Apr 2, 2021 | 10:58 AM
SteveG75's Avatar
SteveG75
All old school small blocks and big blocks have the same firing sequence.
1-8-4-3-6-5-7-2
Just make sure you have good separation on the 5 and 7 wires to avoid misfires.
Old Apr 2, 2021 | 12:04 PM
MelWff's Avatar
MelWff
It's really unclear as to how long it's been since this engine was started?
When you brought the engine up to #1 TDC did you remove the distributor cap to see where the rotor was pointing?
Old Apr 2, 2021 | 05:28 PM
grumman41's Avatar
grumman41
It has been started in the last month. When I’m on the compression stroke(1 cylinder) and the timing is roughly 10 degrees prior, the distributor won’t allow me to start the 1 in the correct spot so everything is one space forward. Shouldn’t be an issue, correct?
Old Apr 2, 2021 | 06:06 PM
MelWff's Avatar
MelWff
you are basically saying the distributor loosened and is no longer having the rotor point roughly to #1 so your distributor timing is way off and wont start. When you are on #1 TDC turn the distributor so the rotor is directly pointing at #1 in the cap then tighten the hold down clamp.
Old Apr 3, 2021 | 09:35 AM
grumman41's Avatar
grumman41
Thanks, I tried that. I now think there is an intermittent issue with the spark.
Old Apr 4, 2021 | 09:17 PM
grumman41's Avatar
grumman41
Gents, I’m still working thru this starting issue. I verified I am getting fuel, the bug and distributor cap is new and ran great on the dyno. I verified the wires are in correct order. I’m now not getting any spark at all, or seems it was intermittent before. I’m thinking a ground or hot wire to the ignition is the culprit?
Old Apr 6, 2021 | 09:34 PM
grumman41's Avatar
grumman41
So, I’m going thru this ignition system one item at a time. I checked the values of the stock coil and it was 11.82 on the high side and 2.2 on the low side. Does these numbers seem in line for a stock Delco coil?
Old Apr 7, 2021 | 09:04 PM
MelWff's Avatar
MelWff
yes, they are within spec but what is the voltage at the positive terminal when cranking and when the key is in the run position?
what is the dwell reading when cranking?
Old Apr 8, 2021 | 01:24 PM
grumman41's Avatar
grumman41
I’ll check that, ground at the coil - or earth for this test? What should it read?
Old Apr 8, 2021 | 08:51 PM
grumman41's Avatar
grumman41
I checked the voltage at the coil with the engine cranking, it read about 8 volts.
Old Apr 8, 2021 | 09:31 PM
forman's Avatar
forman
check your wires good I bought brand new wires and chased the same problem ,, MSD brand new wires and had to recrimp 3 of them ,,,drove me crazy for a month
Old Apr 9, 2021 | 09:07 AM
grumman41's Avatar
grumman41
I’ll try another set, also going to drain the fuel system. The fuel has been setting.
To LS 5 timing order
