Latest consensus on using Silicone Brake Fluid
LONESTAR voids the warrantee for a reason, Silicone soaks into EPDM (and other rubbers) lip seals and o-rings....causes them to swell and become non-functional.
My two cents...for a C-3 nothing but DOT4 should do.
You can mix dot 3 and dot 4....but dot 4 has a higher boiling point.
Unkahal
This is the best place to get answers or Information on anything Corvette Related.
I too have a 1968 Early October 427 Convertible Corvette equipped with a Holley Fuel Injection. It has Power Brakes, Power Steering, Power Windows. I rebuilt my 427 into a Torque monster. The 427 runs well with the high compression and I rarely have to use any fuel additives as long as the air is cool and I do not have to work the engine too hard. On a mountain trip I activate the water/Ethanol mixture into the air flow. This very quickly makes the fuel become 116 Octane which stops limiting.
Good Luck with your Corvette and if you have any questions "we can help"
When I built the new engine about 6 years ago, I used 10.5/1 pistons with open chamber heads so I could finally run pump gas. During all my autocrossing days I had a 454 LS6 block with closed chamber factory replacement L88 heads which gave me 12.5/1 compression. Once the gas got bad, I always had to use octane booster. I have a melted piston sitting over my desk to remind me of what happens when I didn't use it.
