4 speed leaking by tail section
Old Apr 16, 2021 | 05:39 PM
SVASSH's Avatar
SVASSH
St. Jude Donor '21
Default 4 speed leaking by tail section
Hi fixed my rear seal and oil pan leaks last week. Want to attack the transmission next. See the photo pretty bad leak where tail section attaches. Any advice on my options
to approach this without pulling the transmission?
Old Apr 16, 2021 | 06:20 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
If you are referring to the gasket or O-ring between the rear of the case and the tailshaft housing......
use a degreaser to remove all oil and grime to pinpoint the leak......
find the tail housing bolt torque specs. and retorque the bolts to the high side of the specs....
......cheap&fast.
Update us.
Old Apr 16, 2021 | 06:22 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
About the only thing you can try is to tighten up the bolts. To repair it properly. the trans has to come out.
Old Apr 17, 2021 | 05:41 AM
stingr69's Avatar
stingr69
Check output yoke seal and speedometer bullet O-rings. Those are pretty easy. Might not be a transmission gasket leak at all.
Old Apr 17, 2021 | 07:57 AM
SVASSH's Avatar
SVASSH
St. Jude Donor '21
Thanks all I'll try to torque it down and check other areas noted.
Old Apr 17, 2021 | 08:58 AM
Shovels and Vettes's Avatar
Shovels and Vettes
I had the same problem, took the transmission to shop, they put new gaskets in,.....still leaks. I give up. It will just have to drip on the floor. And people say Harleys leak.....my 2004 Road King never leaves a drop.
To 4 speed leaking by tail section
